Honda S2000 Honda S2000
Need opinions.. Enkei NSX setup on AP1
Old Nov 29, 2008 | 06:38 PM
24boosted's Avatar
Default Need opinions.. Enkei NSX setup on AP1
I picked up a set of classic Enkei RP01s for cheap. They came off an NSX. The specs are 17x8 fr 18x9.5 rr +38 offset all.
I'm currently dropped on Espelir springs with Koni shocks. I haven't had a chance to do alignment yet and wanted to figure out what to dial in after I did some research, so hence this question.
What do you guys think? Run these wheels or sell and get something more fitting? What should I align the car at if I do run these wheels?
Tires going on will be 245/40s in the back and 225 fronts, stock body.
Old Nov 29, 2008 | 08:04 PM
Black S2K's Avatar
yea um i dont think they will fit and not rub if you dont roll
Old Nov 30, 2008 | 08:53 PM
efstile's Avatar
get to rollin those fenders, and don't expect to have perfect camber.
Old Dec 1, 2008 | 05:01 AM
slow poke's Avatar
Those are pretty aggressive. Your fenders will need allot of work and you will have to add a nice bit of camber to run these wheels if you are lowered.
Old Dec 1, 2008 | 05:41 AM
18psi sohc's Avatar
The front won't be to bad. The rear is going to need a little massaging to get them to fit tho. Post up pics!
Old Dec 5, 2008 | 06:35 PM
ITRbroham's Avatar
shit post warrior
The NSX wheel sizes make the S2k resemble a dune buggy.
Old Dec 5, 2008 | 08:05 PM
S@nt0s's Avatar
Munkyw3rkz.webs.com
stick to the 215 front, less headache.
otherwise roll and massage them in.
Old Dec 5, 2008 | 11:08 PM
XenonKiller99's Avatar
I have a setup of 17" Enkei RPF's, T1R coilovers, 255/40/17 Azenis RT-615 all around w/ wide front fender flares. No rub front nor rear. Perfect.
Old Dec 6, 2008 | 09:04 AM
Black S2K's Avatar
^ pics plz
Old Dec 7, 2008 | 08:32 PM
24boosted's Avatar
Anyone interested in trade? AP2 v1/2/3 stock wheels for these.
http://www.hondamarketplace.com/show...176&highlight=
Old Dec 8, 2008 | 03:55 PM
- BSeRiouS -'s Avatar
The specs are very do-able I may say.
If you have all the proper fender/suspension work done; cut, roll, pull, trim, relocate, camber, etc etec you can run a 255/225 set up and It will make your car look that much more amazing. However, you will be more prone to rubbing if the rear 1/4s have not been tampered yet. A 245 will have a nice little stretch to it, giving you the clearance needed, but it won't look as a hard as a 255 imo. Just a thought
Old Dec 10, 2008 | 07:16 AM
White Smoke's Avatar
i my honda
Global Mod
This post is pointless with out wheel sizes...
jdmcx
Oct 24, 2011 04:42 AM
rudyndrew
Honda Fit
13
Mar 6, 2010 10:52 AM
xfrankx
Mar 2, 2010 11:25 PM
jdmhondaboi626
Nov 21, 2007 09:53 PM
asianbluesi
Nov 21, 2007 07:18 AM
