where does this mount
You sure its the head? Pull the cap off the distributor, if you got oil in there, the shaft seal failed, replace the distributor, Most common leak. There are no oil passages right there, only return holes.
Anytime one sees oil around the dizzy, it is going to be either the o-ring as shown below or the oil seal as shown below.
Oil right beneath the inboard end of the dizzy suggests the o-ring has failed. Pull the whole distributor off, and you will see the o-ring.
Oil in the dizzy cap suggests the oil seal has failed. Replacing the oil seal requires a bit more disassembly. For how to replace the oil seal and where to buy a new one (since Honda dealers do not sell it), see several of the steps in
http://honda.lioness.googlepages.com/distributorbearing.
ok heres the deal me and my friend ajusted the dizzy and the timing it runs a hell of a lot better but i pulled the dizzy cap off and theres no oil in there but it looks like theres oil leaking outa where it mounts to the head but im not fersure its kinda hard to get down there would this be the o ring
Worst case an o-ring that you get at True Value or Autozone will leak a heckuva lot. Middle case it will leak a little. Best case it will be just fine. bkhondaparts.com has dimensions of 26.4 mm x 3.1 mm on the o-ring. Dunno if the 26.4 is ID, OD, or midway between. The 3.1 mm should be the thickness. I do not know for what kind of temperatures the one Honda sells is designed, so I do not roll the dice on this one and go OEM. Plus I know how to order from the internet (nudge). But you're young, and maybe low budget? Weren't we all. Experience builds character.
