Engine starts, then stalls (No Power)
Old Nov 29, 2008 | 02:22 PM
slowcivic2k's Avatar
Default Engine starts, then stalls (No Power)
This seems to happen the most when its cold, (IE 30F or lower) and it tends to come and go from time to time. When I turn the key to START after letting it prime, almost right after cranking (I believe as the key goes from START back to ON (II) ) it will fire and then stall. When this happens all the power in the dash lights is gone, nothing. Not sure about the headlamps or console yet. It recovers within a split second, and the power is back on. Sometimes when it does this the engine is moving fast enough that even when this outage occurs, and the power comes back a split second later, it will catch and keep turning, so it cannot be powertrain related.
Anyone with this problem or one that is similar chime in.
Geis
Jul 16, 2016 07:59 AM
turkdavid
Dec 26, 2013 11:13 AM
