1997 accord se foglight diffrent?
hi guys, i found a great condition fog light harness for 1997 accord se, thing is i asked the guy if they will fit the 95 ex (97 front bumper), and he said no. does he know what he's talking bout cuz im pretty sure they do, n i can't find anything on google. also, does se mean special edition? thanks in advance.
The OEM Honda Accessory Fog Lamp kit (for the '96 and '97 Accords (all Models) was installed in the lower grille assembly. It required cutting out several of the flutes on each end to install the lamps. The '94 and '95 was simular, but Honda called out a different Part Number for the kit.
I would think (only because I never had any reason to compare them) that everything EXCEPT the lamps would be the same (It IS the same car, just different Bumper Covers / Grilles
The harness will be the same and will fit. The only reason there was a different kit for the "SE" (and a different part number) was that the switch for the fog lights went in the console near the ash tray and was a different size/shape than the normal switch that went in the dash to the right of the clock. On the SE model the factory "Security" system light went in the empty switch position on the dash.
Skip888
Jan 4, 2009 10:17 PM
nicolaselias
Feb 10, 2008 07:31 PM
