Suspension & Brakes Theory, alignment, spring rates....
Ok.. so my omnipower coilovers SNAPPED
Old Nov 29, 2008 | 12:53 PM
Mashburn595's Avatar
Icon6 Ok.. so my omnipower coilovers SNAPPED
I've been using omnipower products for quite sometime now.. all of my friends.. i've known several people to use these coilovers and trust them.. i've used them at least a year or two.. had a set on my daily driver and my race car...
Well i was driving down the road in front of my house in the neighborhood and i heard a loud ''pop'' then i lost complete control of my car and the chassis hit the ground..
here's the aftermath:
It's a good thing i wasn't on the interstate..
Old Nov 29, 2008 | 01:11 PM
pgpbubble's Avatar
wow, id call omni. how old were they?
Old Nov 29, 2008 | 01:16 PM
Riced-EL's Avatar
HOLY ****...Thats quite a bit of damage. Call them up for sure. I believe theres a 1st and 2nd gen on omni coilovers, where the 1st gen's are known to snap. I hope you get reimbursed on such BS.
Old Nov 29, 2008 | 01:27 PM
integrawow's Avatar
What'd you do, run over a land mine?
LOL, man that's some serious damage. Hmmmmmm. Yikes.
So you were just driving nice and easy weren't you?!?!?!?!?!?
Old Nov 29, 2008 | 01:32 PM
Jimmy's Avatar
Global Moderator
Jerry.. I'm sorry this happened to you.. and i'm glad your ok
This is a major problem from what i've heard of.. it was the first gen omni's.. which are the same one's on my car as well..
Old Nov 29, 2008 | 01:40 PM
RedneckRicer's Avatar
ya known issue. wonder if you will get compensated for the damage done to your car from a known faulty product. I forget who but i remember a drag racer that took a wall shot OR almost took a wall shot when his omni's snapped.
Old Nov 29, 2008 | 04:34 PM
katzenjammer84's Avatar
"Known issue" and "snapping in half" shouldn't coincide with one another. That's just flat out dangerous.
Old Nov 29, 2008 | 07:47 PM
m_shake's Avatar
atleast it didn't fail on a mountain road or something. hope this ish gets resolved by omni
Old Nov 29, 2008 | 08:53 PM
Civichatch2k's Avatar
To me it looks like his coilovers were on the lowest possible seating which in the Omnipower instructions it strongly advises against.
I have the first gens and I have not had a problem and I push my car at times. I have had them since they first came out so it has been at least 3 years or so. I love them.
This does concern me and I am glad you are OK.
I just wonder if the low setting of the Coilover put extra pressure on the bottom of the shock body cause it to wear abnormally.
Just my .02. Definately call Omni. That is an issue that hopefully they can help you with.
Old Nov 30, 2008 | 11:12 AM
Riced-EL's Avatar
Why make a product that offers a feature - in this case going low - but not allow it? If the product was not able to handle such stress...I feel that they should have not threaded the coilovers that far right?
Old Nov 30, 2008 | 11:54 AM
Like anything else, it comes back to you get what you pay for.
Old Nov 30, 2008 | 03:10 PM
shutta's Avatar
if they strongly advise against using their part in any location of the adjustment range, they are ****ing idiots in my book. if it's an designed to adjust that way, it shoudl be safe. if the part isn't safe to use that low, they shouldn't have made it like that. ****ing retarded. you better get reimbursed.
Old Nov 30, 2008 | 03:30 PM
Most companies will say the shock warranty is voided if you go past a certain level of adjustment, so maybe there is their reasoning. However, that is for damper longevity, not the structural integrity of the entire system.
Old Nov 30, 2008 | 03:52 PM
Riced-EL's Avatar
I understand that. But to make a product that has a feature, only to advise consumers not to use that feature, is idiotic. It sort of shows the amount of R&D that might have went into this product.
Old Nov 30, 2008 | 04:11 PM
See my previous post.
BTW, I am in no way a supporter of OmniPower, I'm not trying to defend them. I've always thought of their stuff to be 2nd rate.
No offense to anybody who owns any of their products, just my opinion. This furthers it.
Old Nov 30, 2008 | 04:24 PM
rickoner's Avatar
i would think that if it was lowered all the way down, you'd more than likely be hitting the bumpstop on occassion. all the impact/shock would go into the shock body. then the weakest link broke. glad to see that nobody was hurt though.
Old Nov 30, 2008 | 04:38 PM
Tyson's Avatar
it failed because theres less than 2mm thick of soft aluminum material on the shoulder of the cup.
they say it was a "bad batch". whatever that speaks of their non existent quality control... yup, they knew about it. quite frankly, i thought everyone knew about it. but thats no excuse for them not to own up to this. theyll likely just offer a replacement set of coilovers, as long as you pay $100.
i wonder how long these pics are going to stay up once the OP contacts omni...
Old Nov 30, 2008 | 06:45 PM
hondadriver's Avatar
What are those 2 pieces held together with, ****ing super glue?? jesus christ, what a shitty design. Thats scary stuff!!!! I always thought coilovers that had that design were one piece tubes. There should be a solid weld goin around to make a strong connection between the 2 pieces.
Old Dec 1, 2008 | 10:40 PM
ahobbs's Avatar
HELLO,GOOD MORNIN'
wow, i hope i dont deal with this
Old Dec 1, 2008 | 10:45 PM
SlowReaction's Avatar
This was problem that I was first discovered when they first came. The first set that broke was on a civic drag car. It caused a lot of damage from what I could remember. Omni did offer to replace all the lower sleeves as long as you had a receipt for proof of purchase from a authorized dealer. Sorry to see this happen to you.
Old Dec 1, 2008 | 11:00 PM
allmotorek4's Avatar
almost every omni product ....
almost every omni product has a bad ending ....
Old Dec 1, 2008 | 11:15 PM
lmananT's Avatar
lawsuit anybody?
Old Dec 2, 2008 | 10:44 AM
A Blue Lude's Avatar
Somehow "free replacement" doesn't seem like something desirable.
Old Dec 2, 2008 | 01:47 PM
Riced-EL's Avatar
So is there any way to see when an Omni coilover maybe a Gen 1 and when it maybe a Gen 2?
