Intake manifold butterflys
Old Nov 29, 2008 | 10:19 AM
Prudz_lude's Avatar
Default Intake manifold butterflys
So i was taking apart my IM last night and i was trying to remove the butterfly plates. I got the actual plates off but i have no clue how to remove the rod that holds them. Should i just remove the plates that hold the butterflys?
Before someone posts this, i just finished reading that 7 page thread in the faqs section about the IM's. I read most of it but skimmed through 2 pages. I might have missed something on the plates/butterflys but i doubt it. It seems to focus mainly on Port work and chopping up IM's comparing them to the RSX's.
If someone has an answer on how to do this/what is should do please let me know.
Old Nov 29, 2008 | 10:29 AM
92hondalude's Avatar
are you talking about the studs that hold the plate and plemium down?
Old Nov 29, 2008 | 10:31 AM
snobordboy's Avatar
Moderator
Adam, if you remove the rod, you have to weld the holes shut on the side of the manifold, so just leaving it in is easiest. But while your talking about that system, do you have the plastic box that controls them? Mine the ports all broke off and I need a new one!
Old Nov 29, 2008 | 10:39 AM
Prudz_lude's Avatar
I am talking about the plate itself that holds the rod in place. I did noticed that if i removed it i would have to do something about the holes. I think i will just remove the plate completely.
I do have that plastic box that controls them. You can have it once i figure out what i can/cannot do with this IM.
Old Nov 29, 2008 | 10:51 AM
snobordboy's Avatar
Moderator
Hmm, yeah I honestly have'nt dug that into mine, I like the plates working for now, I have noticed a drop in low end torque with them not working. Very evident when going uphill in the mtns at 8000+ ft elevation, had to stay over 4000 rpm to keep speed up, when my h23 pulled the same hills fine at lower rpm and the iab's working.
Old Nov 29, 2008 | 10:54 AM
Prudz_lude's Avatar
Hmmmm, maybe i will keep them then, i don't know. This is for my f22/h23 franken motor build, not my h22 build. My h22 is using the skunk2 pro series. I realized the other day i have all the parts for the build including an h23 tranny so why not just build the motor and swap it in a chasis with a blown motor for a good DD I still want to crank a couple extra ponnies out of it though.
Old Nov 29, 2008 | 10:55 AM
yes you will loose low end and gain very little high end if i remember correctly. That why i ended up going with the blacktrax stage 2 ported manifold on my old all motor setup. If you are running a stock ecu i would just keep it the way it was. I changed it because i was running hondata with a p28 and a p28 doesnt control the butterflys.
Old Nov 29, 2008 | 10:56 AM
Prudz_lude's Avatar
It is actually going to see a junkyard dsm turbo kit as well so the ecu won't be stock and the airflow is not the same. I know larger volume IM's typically provide better power for turbo systems which is why i wanted to know how to remove the butterfly rod. Ecu will obviously be chipped and the car will get a street tune and possibly a mild dyno tune.
Old Nov 29, 2008 | 11:04 AM
oh i must have missed the part that you were boosting it haha. blacktraxs makes spacers might look into that also.
Old Nov 29, 2008 | 11:06 AM
snobordboy's Avatar
Moderator
Yeah I didn't think this was the boost project you were discussing, since a boosted car is going to more top-end oriented anyways, might as well take them out, weight and flow savings ftw!
Prudz_lude's Avatar
i never mentioned it until just then. I called a few junk yards in my city and managed to piece a kit together for $220 .
Old Nov 29, 2008 | 11:09 AM
lol weight!
Old Nov 29, 2008 | 11:32 AM
Acidcrakker's Avatar
Ive done this before, I used a rotary tool to cut both ends off of the rods. They are on the outside of the plate. you will have to JBweld, or plug the holes up when done
Old Nov 29, 2008 | 12:44 PM
Prudz_lude's Avatar
Thanks guys!
Old Nov 29, 2008 | 12:51 PM
teefunk01's Avatar
Ive seen a few people make a spacer plate to lenthen the runners a bit to
Old Nov 29, 2008 | 01:01 PM
Prudz_lude's Avatar
yah someone in my city did that on their h22 build.
Old Nov 29, 2008 | 06:41 PM
pheurton-skeurto's Avatar
Prudz...i've been working on my stock H22A4 manifold for a while now. my problems started when i switched to hondata and a P28 ecu (which doesnt control the butterflies). i was turbo (greddy kit) and ended up switching to the ugly but somewhat functional OBX manifold. now im switching to a big setup (600+ hp) and im going to try out a few different things; one of them being to just hog out the stock manifold. i started in on it and finished gutting the top half and decided that rather than gut the butterfly section, id just go with the blacktrax spacer--just to add volume to the plenum.
in my experience though, there's really no way around cutting the rod holding the butterflies on the ends and pulling it out. once its out you can either weld/jb weld the end holes or the end holes along with the individual runner holes.
Old Nov 29, 2008 | 09:30 PM
Prudz_lude's Avatar
Thanks, that post gives alot of details. I am leaning towards just jb welding the rod holes. I have not cut them yet but i think that will most likely be the case.
Old Nov 29, 2008 | 10:09 PM
viper_boy403's Avatar
Prudz, when I got my chipped P28 from Steve (moto) he told me that I needed to disconnect the IAB diaphragm from the control solenoid and connect it directly to a port on the IM since, like said previously, P28's dont have IAB control. Now they open at ~4000 and are closed below that, instead of being open all the time which caused me a noticeable loss in low end torque
Or you can just pull the plate out completely and eliminate the IABs
Old Nov 30, 2008 | 02:28 AM
prelude_93vtec's Avatar
Anyone ever try to put a bolt in there inplace of the holes?
Old Nov 30, 2008 | 10:20 AM
98vtec's Avatar
moderator emeritus
just take the plate out completely.
Old Nov 30, 2008 | 05:40 PM
Prudz_lude's Avatar
Yah i was thinking i would just remove the plate. I don't want to spend money on a blacktrax plate since my DD is on a strict budget. Thanks guys for all the replies.
MoreCowbell
Oct 27, 2011 03:34 PM
driveslow
May 11, 2009 07:23 PM
coreyhayman
Sep 29, 2006 06:38 PM
Honda_RN
Aug 3, 2005 04:17 PM
b18psi
Jun 30, 2004 09:29 AM
