clicking noise when turning
Old Nov 29, 2008 | 07:21 AM
lilshady6796's Avatar
Default clicking noise when turning
ok when i turn right i hear my cars front passengers tire area start sounding like its clicking what is this problem
Old Nov 29, 2008 | 07:29 AM
rick1574's Avatar
axles.
Old Nov 29, 2008 | 07:33 AM
would i have to replace passengers side axles since its on that side or both
Old Nov 29, 2008 | 07:37 AM
95jeremie's Avatar
just the passengers side will do
i would replace them at the same time if the wallet wil let you
autozone axles are lifetime warentied BTW
Old Nov 29, 2008 | 07:38 AM
ok thanks man
Old Nov 29, 2008 | 08:02 AM
honda_boy23's Avatar
remember to take the cores in and get some money back
Old Nov 29, 2008 | 08:43 AM
Sean @ ESG's Avatar
It's the CV Joint that makes the clicking noise. Jack up your car and see if the boot is ripped, or if there is grease around the area and your wheel. Like everyone said, you'll have to replace the axle.
Old Nov 29, 2008 | 10:52 AM
l3adunkadunk's Avatar
i had that same problem in my 91 dx civic, i would recomend having your driveshafts looked at...i cant quite remember what was the problem but i had my alignment done which helped alot but didnt quite fix it.
on mine it wasnt to bad on wide turns but i felt like i was going to snap something on tight u turns or sharp corners...same for you?
Old Nov 29, 2008 | 01:34 PM
98civdx's Avatar
Master Detailer
replace the cv joint or just buy full axles with new cv joints
eihter way you need new ones
a.wax
Feb 15, 2009 09:36 PM
Civicracer17
Mar 17, 2006 06:21 PM
lowRIDAH
12
Dec 27, 2004 09:05 AM
cbmlsvteg
Oct 17, 2003 06:15 PM
ceas
Dec 15, 2002 05:14 PM
