Intermediate Shaft will not go all the way in (Richmond Spool
Old Nov 29, 2008 | 05:53 AM
jasonp's Avatar
Default Intermediate Shaft will not go all the way in (Richmond Spool
I have a 94-01 GSR Intermedia shaft (2 of them) and just installed my New Richmond GSR Spool and I can't get the intermedia shaft all the way in.. any suggestions.? or others have this problem.. thanks.
Old Nov 29, 2008 | 05:59 AM
rota92
Guest
Posts: n/a
Get a bigger hammer
Old Nov 29, 2008 | 06:01 AM
DaveF's Avatar
what transmission are you using it on ? perhaps you have the wrong axle seal ?
Old Nov 29, 2008 | 06:44 AM
Turbo-charged's Avatar
that almost seems impossible since the spool is splined the entire way through. i put a richmond spool in a b series trans the other day and didnt have any issues.
is the trans in the car or on the bench?
Old Nov 29, 2008 | 06:53 AM
2manySecCivic's Avatar
Originally Posted by rota92
Get a bigger hammer
He may be right, however I would use a mallet. On my car for what ever reason I have to pound the half shaft in and out. Forgot what spool I have. I say as long as it splines and goes in a lil ways shouldn't be a problem to knock it in, as much as I hate to force stuff.
Old Nov 29, 2008 | 06:54 AM
jasonp's Avatar
B series Tranny and the axle seal is out of it right now.. I see that the splines do go all the way thru but on the intermedia shaft they are about an inch and 1/2.. and that is where the shaft stops... and a bigger hammer doesn't work either... lol...
Old Nov 29, 2008 | 06:58 AM
ek9t72's Avatar
joe you may had the new desing I put one in my car 4years ago and my dss had the same issues to fix it I took both axle to the machine shop and had then mill a little where the splined end that will let the axle go in all the way
Old Nov 29, 2008 | 07:11 AM
BoostedJeff's Avatar
nah i know for a fact that the one he installed was purchased at least 4 years ago
Old Nov 29, 2008 | 07:16 AM
jasonp's Avatar
I just recieved my spool direct from Richmond on Wednesday.. and the intermedia shaft is the problem..
Old Nov 29, 2008 | 07:18 AM
you may want to run your fingers along the solines of the spool/half shaft and make sure there are no burs or nicks.
Turning it down isnt a bad idea but honeing the spool might be better if you ever have to replace and axle or half shaft you will have to turn them down all over again. I would msr. everything first though. Did you try the axle on the pass. side yet? did you use and astro glide?
Old Nov 29, 2008 | 07:23 AM
jasonp's Avatar
there are no burs or nicks and my axles are at DSS right now so I can't try the pass. side.. it looks like I run out of splines on the intermedia shaft before it goes all the way in..
Old Nov 29, 2008 | 07:27 AM
swing the bracket up to the block. how far are the holes from matching up to the block?
Old Nov 29, 2008 | 07:43 AM
tricura's Avatar
We have installed several of them and never had a problem. Take the clip off the pass side axle and see if that slides in, if not sounds like bur or it is in all the way.
Old Nov 29, 2008 | 07:47 AM
civicxpress's Avatar
i just had the same problem. gsr tranny. i had a richmond spool and the shaft fit fine, needless to say my dss axle kept popping out because the diameter of the richmond was off by.0030. finnnaly it popped out on the dyno a few weeks back and wiped out the splines in the spool and broke the tranny. i went and bought a tci spool and the fitment was way better but the same shaft i had used before would not go in all the way. i beat it, ground down the shoulder and tried every dam thing and it would not go in. i had my buddy bring me another shaft and it went in a lil more. but was still out about a quarter inch.... soooo since i had a spare shaft i decided to make the splines a little longer by taking a cut off wheel and making the grooves longer. it went in all tha way!!
dont know why it fit in the richmond and not the tci and i had no problem with it hitting the axle on the passenger side axle. went to the dyno the next day and made 857whp wit that shaft but i brought the spare to a machine shop and had them do it properly so it wasnt hacked. not sure really why i had the problem there must be different shafts b16 or something???
Old Nov 29, 2008 | 08:12 AM
integrawow's Avatar
I put a richmond spool in an S1 cable transmission (B16), and had no reverse. Then I had a professional go through it and when I got it back, I bench checked it and all the gears were there, but for some reason, I bolted it into my car, and checked it with a screwdriver just as I did it on the ground (totally eliminating the potential of having a car shifter problem) and the result was no 5th gear. So for some reason, I have had only problems with 5th and reverse since the addition of the spool.
I can't figure it out. I'd hate to think there is some sort of compatibility issue, but I am just not sure.
Old Nov 29, 2008 | 08:39 AM
jasonp's Avatar
thanks everyone but I gotta pull the tranny out and talk to Richmond monday..
Old Nov 29, 2008 | 01:07 PM
i woulnt pull the tranny to pull the spool at all you are just wasting time. the splines on the spool go all the way through. the intermediate shaft is the problem!! the splines are bottoming out. when i flipped my bracket up to the block the bolt holes were half on. just a half a bolt hole off!! where is your alighnment at?
Old Nov 29, 2008 | 02:01 PM
jasonp's Avatar
that is the problem... what did you do or what did Richmond do... I have it all torn apart and was waiting for Monday.. thanks for the help..
Old Nov 29, 2008 | 07:14 PM
Default what i did
Old Nov 29, 2008 | 07:18 PM
jasonp's Avatar
so you or anyone else call Richmond and ask them about the problem.. I don't fell like grinding on the intermediate shaft unless Richmond suggest it.. thanks. again.
Old Nov 29, 2008 | 10:04 PM
Mista Bone's Avatar
D Tranny Guru
per Joe Demetree (spelling) chuck the soft Richmond spool. it will twist the spline in the diff, making axle removal impossible.
Richmond LS spool I installed for a local customer
Twisted Richmond Joe had in his trailer and showed us.
Old Nov 29, 2008 | 11:07 PM
mec. pedri's Avatar
this **** is not rocket science
have the intermediate shaft machined
done it a couple times with zero issues
Old Nov 30, 2008 | 04:03 AM
jasonp's Avatar
I will take it to a machine shop, just don't understand why We As Racer's should have to Modify a part that should bolt right in.. Just my 2 Cents...
Old Nov 30, 2008 | 08:59 AM
1junkycivic's Avatar
Richmond spools are cheaply made.
Old Nov 30, 2008 | 11:48 AM
it has to be something with the shaft. mine fit fine in the richmond but didnt fit the tci.
