Front End Help plz
I have a 91 Integra. A little while ago i basically hit a curb with the right front tire and bounced off of it. Needless to say i bent something in the front right end but i don't know what specifically i bent. Is there anyone that knows SOMETHING about the frame or axle that could point me in the correct direction of fixing or replacing some parts?
you probably bent the tie rod or radius rod. the lower control arm and shock fork are bost cast steel, so they pretty much wont bend, only break.
if it was the axle or the ball joint, there'd be a noise associated with the effects youre noticing.
