question about light flywheel
ok so im thinking its about time to get a new clutch in my dc5 i was thinking about doing a lighten flywheel, the only thing is that i did one in my integra ls with a built head. I think it hurt me more them helped me. So i was wondering who is running a lighten flywheel and does it help you and how many pounds is the stock flywheel?
i ran 9lb and stock is 14 or 18 i cant remember, revs are faster and i still managed 164 tq on a mustang dyno, i actually have that wheel for sale b/c i blew my motor if your interested after your research
How did it hurt you? The only way it could is if you're a drag racer. Otherwise, less weight on the drivetrain is never a bad thing.
All a flywheel (basically) does is store kinetic energy. The heavier it is the more it stores. But the heavier it is the more (power) it takes to build it up.
I have heard mixed results on lightweight flywheels. Some say it takes a little getting used to cause the revs drop quicker. I have driven cars with both. I know I want to get the Type R flywheel eventually.
I think they are cool. My friend has a 94 Mazda MX3 and he swapped out the 1.8L V6 for a 2.5V6 KLZE from Japan. It has a lightweight flywheel. It revs like a sport bike all the way to 8000 RPMs. Its pretty sick hearing a V6 rev that high and start shooting fireballs (he runs pretty high fuel pressure). Haha.
This affects any car regardless if its a drag car. I think its more important for a daily driver because you shift slower. 8 or 9lbs flywheel and you go to shift and you are at idle. Also sucks to get going, especially with the ac on.
I would never get a lightened flywheel for a DD.
Thats why you stick with the street light which is around 10-11lbs. Around the same as a Type-R stock flywheel. I have no problem DD and I run a 6puck Stage 4 competition clutch on my DD. Grab and go
hmm...i've recently pciked up an ACT sport FW from one of the techs at my dealership...i've also heard about kinetic energy/inertia issues with starting and climbing hills, etc. i was just going to hold on to it until i upgrade my clutch...seems like the best idea considering i'm not running much more HP/TQ over stock '04 type-s motor and it is my DD...comments anyone?
i have a 9 lb on my dd, it has never made a difference on my driving, if you know how to drive a clutch properly then u can drive a car with a lighten flywheel all day up and down hills and not have a thing to worry about, it is a minimal mod at best, quit fretting over it like its a turbo kit or something
It all depends on how you feel... I had a 7 pound flywheel with a stage 3 clutch on my B18C5 and I loved... it was fun... but my dad always had a hard time with it lol
i have a exedy 9.8 lb flywheel on my gsr and i probably won't get such a light flywheel for my si. it's fun at first but gets annoying for dding after a while, as you have to shift super fast during regular driving or the rpm will be at idle. also, it seems like i have to give it more gas when starting off.
more like 0 hp. a flywheel doesn't increase your engine power.
I forgot where I was reading it... I wanna say sport compact car but they claimed that a lightweight flywheel because of less rotating mass will equal quicker acceleration similar to gutting an interior... Sound like it could be true?
Yes the revs will go up quicker and you will get a bit better acceleration but you have to keep in mind that if the revs go up quicker they will also fall as quickly! So you would need to shift a little quicker... it demands just a little more work and getting use too... nothing hard!
