what to spray on squeeky clutch
Old Nov 28, 2008 | 10:26 PM
PowerLeg's Avatar
Default what to spray on squeeky clutch
my clutch squeeks and i need to know what to spray
ppl say wd40 is bad because it DRIES out soon after and makes stuff even worse i.e) door hinges etc
what should i spray on a squeeky clutch that last a long long time and not bs item
thanks
Old Nov 29, 2008 | 01:20 AM
majinsoftware's Avatar
ummmm dont put anything on your clutch it will just make it slip and your car wont move.
If its squeaking its worn out and is only gripping with the rivets or the springs.
Old Nov 29, 2008 | 01:26 AM
Paul-R's Avatar
wtf is this thread about ? putting lube on your clutch ? what a dumb azz ! lol i think you mean the clutch pedal ? if so any lube grease will do but do not I MEAN DO NOT PUT NOTHING ON YOUR CLUTCH LOL
Old Nov 29, 2008 | 03:20 AM
miketrue's Avatar
yeah i think he means the clutch pedal. im also having the same problem, but only when the weather is cold out. where should i put the lube grease???
Old Nov 29, 2008 | 06:30 AM
the_augie's Avatar
theres a spring on the topside of the pedal, up under the dash. use some white lithium grease or jb80 or wd40.
either that or turn your radio up louder.
Old Nov 29, 2008 | 10:20 AM
SkaiWu's Avatar
^ yea that
mine squeeks too, usually moreso when its cold
i didnt spray anything because it didnt really bother me and yes i also heard wd40 is not good when i checked out a squeeky clutch pedalthread a while back
jdmstyleEJ6
12
May 9, 2010 04:13 PM
xunkn0vvnx
Mar 30, 2005 07:52 AM
