Where to:Vacumm diagram on blox manifold,
Old Nov 28, 2008 | 10:25 PM
acmoc's Avatar
Default Where to:Vacumm diagram on blox manifold,
Hi, I need a little help with this, mostly the fuel pressure regulator, there's one in place where I labeled it, but on the stock manifold, one is already their. So I was thinking, do I use a T adapter their or plug the other one and run the fpr on that one only. any help apreciated. Thanks.
Old Nov 30, 2008 | 09:45 PM
slowcivic2k's Avatar
You have them in the right spot. That manifold is designed for a OBD2 motor. You have two choices for the brake booster, and both will work, I would use the back one. The front one is for the EVAP purge line.
Karsten
Jul 19, 2018 12:06 PM
95civicohyeah
Dec 20, 2007 11:36 AM
donvito#1
Apr 2, 2007 01:48 PM
TroyL
Oct 30, 2002 08:15 PM
