Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Louder Horn
Old Nov 28, 2008 | 08:14 PM
jomamma1's Avatar
Default Louder Horn
I want to add a louder horn to my wife's 2005 civic. I want to leave the existing horn as is and just add a relay to the existing circuit and run directly off of the battery. I don't have a wiring schematic or diagram to show where I can tap into the existing horn wiring? Can anyone help or direct me to a site where I could find a wiring schematic?
Joe
Old Nov 29, 2008 | 08:44 AM
Philip's Avatar
I just did this to my wife's 2003 pilot. In 2003 the horns (there are two -a high and low) look like civic horns (the small metal disc). In 2004 they upgraded to the plastic "sea shell" looking horns. I simply replaced the wimpy horn with the beefier one from a 04 pilot.
Couldn't you just replace existing horn with an aftermarket louder one? Is there a reason you want to add a horn instead of just replacing existing? I'll try and find a wiring schematic for you to be able to tap off existing horn relay like your post requests...
Old Nov 29, 2008 | 04:21 PM
jomamma1's Avatar
Thanks for the info Philip. First of all, the horn is located behind the front bumper. Sometimes aftermarket horns draw more current than the factory. I don't want to overload the fuse or wiring. If I can find the wire feeding the factory horn, I will tap into that wire and trigger a relay. Then I will take a heavy gauge wire (14 or 12) from the battery via a fuse and fire the new horn.
Joe
Old Nov 29, 2008 | 06:42 PM
unevolved's Avatar
Old Nov 30, 2008 | 06:09 AM
burke420's Avatar
i just bought one from o'reilly's... better than the stock! but not oem'ish!
Old Nov 30, 2008 | 06:22 AM
Worldsport's Avatar
Joe
12ga is overkill. 18ga wire out in the open can handle 10 amps. I doubt your aftermarket horn will pull that much current. Remember to fuse the wire coming from the battery - prior to the relay contact at around 150% of the estimated current draw (NOT to exceed the wires current capacity).
So for example if your new horn draws 5 amps, fuse it at 7.5 amps and 20ga wire will suffice.
Reference material:
(Copper wire in open air for chassis wiring - IE; Not in a conduit)
22ga - 5.0A
20ga - 7.5A
18ga - 10A
16ga - 13A
14ga - 17A
12ga - 23A
10ga - 33A
These numbers are a little conservative so dont worry if you are near the edge.
Old Nov 30, 2008 | 08:53 AM
jomamma1's Avatar
Thanks unevolved and Worldsport, that is just the information I need. This is a great forum. I hope someday to be able to contribute.
Joe
Mr ali
Jan 7, 2019 02:42 PM
The General EJ8
Sep 20, 2011 10:57 AM
civic ferio
Feb 1, 2007 09:58 AM
EK-NICE
10
Apr 10, 2006 08:30 AM
Jockobo
Aug 25, 2002 03:43 PM
