Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Well got to the Dyno with the Acura EL 2.4
Old Nov 28, 2008 | 06:13 PM
Nicholasel's Avatar
Default Well got to the Dyno with the Acura EL 2.4
Well i finally got to the dyno to see oh the old Acura EL k24A2 works out and took some video and some pics.
Enjoy comments are welcome
The test drive
http://www.youtube.com/watch?v=gTF_aLmBQP8
First dyno run
http://www.youtube.com/watch?v=1DiN6...eature=related
Last run on the Dyno
http://www.youtube.com/watch?v=exhN1...eature=related
Some pictures at the Dyno
And the results are in
Old Nov 28, 2008 | 06:42 PM
Harlowe's Avatar
Function>Fashion
Sweeet!
If you don't mind me asking, what is your motor setup? Just a stock K24a2?
Old Nov 28, 2008 | 08:03 PM
ejLday's Avatar
sick man
Old Nov 29, 2008 | 11:54 AM
Nicholasel's Avatar
Well we tried to use the most Honda parts we could on the buil. I got bigger Rod's, dual valve spring using Rsx-Type S spring and putting them in S2000 springs, Tsx intake cam with a Rsx Type R exhaust cam, with a set of OBX Racing headers going into a 2 3/4 pipe with a Maganaflow resignator and a Apexi muffler. Also have stage 2 clutch form Exedy .This is all helled in by Hassport motor mounts and the brains is Hondata K-Pro.
Old Nov 30, 2008 | 11:24 AM
katzenjammer84's Avatar
Excellent choice of motor
Old Nov 30, 2008 | 06:06 PM
unevolved's Avatar
Looks pretty good.
Just out of curiosity, what do you have the redline set at? I was reading something the other day, and they were saying revving an over-square motor like a K24 to 8K rpm without any bottom-end reinforcements is just asking for it to turn into a giant hand grenade.
Old Nov 30, 2008 | 06:12 PM
Originally Posted by unevolved
Looks pretty good.
+1
I wouldn't dare go past 7400 on stock internals.
Old Dec 5, 2008 | 11:21 AM
Nicholasel's Avatar
Well my rpm limiter is set at 7.8rpm , but on the dyno sheet i could technically go further. Well we put some after market rod in the motor just to cover the hight rpm.
But bad news is blew the motor yesterday , the pin that holds the rod and piston together broke and BOOM . So i need to replace the oil pan , oil pump, water pump,the motor block, rods , pistons , jack shaft , radiator and the radiator fan. I got 2 holes in the front of the motor the size of a CD and the same size hole in the back of the motor to . So i am going to rebuild the motor this winter and put a set of stage 2 cams and pulleys in it just for a little more torque .
EG_SINZ
Sep 7, 2010 08:48 AM
Hybrid Jim
Sep 12, 2004 05:02 PM
Alstare
Oct 18, 2002 11:45 AM
