stock hf
are crx hf supose to have like no power cus i cant realy keep it in 5th on the hwy cus of it bogging and takes forever to get gowing and wost of all i tryed to pass this granny on the way home from geten it and i couldnt evan pass her and she was going 40 it just wouldnt get up and go is this normal for a hf
Yeah you won't have any torque to pass on 5th gear, but for it to bog down...interesting. Just try downshifting to get back up to speed and you'll be alright.
****EDIT****
Just re-read your post, if you're bogging down going 50mph in 5th gear there's something wrong. Both of my CRX HF's don't do that...they run fine and only bog down when you're going slow in a higher gear.
****EDIT****
What year is it? I just thought of something. maybe your brakes are dragging. or you could be running on three cylinders or something Worst I think, is a bad wheel bearing or something, something expensive. Do you know if the motor is in good condition or how old it is. You know the hf had the lowest power and most economic transmission, so it's not made to get up 'n go =]
Throw some heet and a bottle of lucas oil stabilizer and injector cleaner too
LOL i remember when i was rolling like this.
you should check your timing.
i remember i couldnt get it to go over 60mph.
turns out that the previous owner had retarded the
timing all the way out.
so i could even chrip the wheels or anything.
lol
check it couldnt hurt only like 2 seconds
lol
yea well i will do all this but when i push on the gas it just seems like it sits there and bogs i dono if thats the way they are and i kno its the most economic one and stuff but it just dosnt seem right like its kinda hard to drive it bogs and almost dies taken off and stuff i dono ill check all that stuff tomaro
The crank pulley has a painted line at top dead center, loosen your timing belt and put that at top, then the cam sprocket has a top line and two side marks. You align the side marks with the head and the top goes up. Then tighten your belt and adjust your dizzy cap to the timing also. You can buy a timing light to check your timing
as far as the bogging is concerned. try a few of the things the others have suggested such as the tune-up and maybe timing. i don't think too many people will mess with the timing on a stock hf but you never know, it could be off.
but just a warning, even after you do that, don't expect to be able to accelerate quickly with out down shifting into a lower gear and getting your rpms up. and even after that you still won't accelerate that quickly because of the transmission and lack of power.
yes i kno that its not guna be fast but it should be better then what it is
i found out today that first pisten has 125 psi second has 170 third has 125 and fourth has like 70 would this mean i need a new head gasket and also whats maken me think its the head gasket is there is oil leaken all around the trany side of the head?? and i will check the timing later
Oil on the transmission, wipe it down real good and drive it a little bit, but not faster than 20 mph so the wind doesn't push the oil, then look for where exactly it's coming from, tell us and we can help where it's coming from k
Yah man, those compression numbers aren't so great at all.
You should try a full leak down test if you have the means.
As for the gearing, I rock my HF daily, and 40mph in 5th gear will have terrible acceleration, but you definitely should not be bogging.
As for the get up and go factor, they are plenty acceptable to drive on the highway, you just have to rev a little bit.
The transmissions are actually pretty amusing.
If your willing to go to redline, like... 4800-5000rpms in an HF, I personally have caught 70mph in second gear. (I know that was stupid to do that to my baby, shoot me.)
So in a real world scenario, come out of second at like 40mph you should be around 3000rpms which isn't bad at all. Then you can just ride third until you get comfortable with the flow of the traffic.
Dude my stock HF motor did 40MPH in 3rd gear.
Fifth gear has no pull, stay in 4th if you wanna pass. Is the car still hesitating?
Also oil leaking on the tranny side of the head is not a headgasket. Its probably your Dizzy seal! Dribbling down.
You know on Hondas, changing a motor is easier than a headgasket sometimes, and cheaper. A sohc zc with tranny would be a complete bolt on, ad if you have the 88 hf, the lightest, It will probably be faster than an si
yea im guna do a b20 swap later on but i just wana try to get it to run right only if it dont cost a lot also the oil is like dark black and dosent oil thin out when its old and could thet be letten it out the exaust and on the moter
dark black? Not sure, milky is bad, means you are getting coolant in your oil
maybe the oil is old, because it burns it, the guy probably just mixes a slew of different ones. Give it an oil change and add some lucas oil stabilizer to stop burning.
