Blinking no seatbelt light
I am running harnesses and there are no stock seatbelts in my 91 crx hf, when the key is on or its running the no seatbelt light blinks and its extremely annoying. Does anyone no how I can get it to stop or what wires to connect under the carpet?
You will have to jump the connector at the seat belts in the door or like stated remove the bulb in the cluster. There is a socket for each bulb on the backside of the cluster. just remove the one with the seat belt light take out the bulb and reinstall the socket.
I did the exact same thing(seat and harness) and I just pulled the bulb out.
you should be able to find those wires under the dash. look in your service manual and it should tell you what color they are and exactly where they run. or pull the bulb in the cluster. lol. whatever u think is easier. good luck
Dekorum
Mar 12, 2010 12:51 PM
DIYMIKE
Jan 13, 2008 08:32 AM
