B16a on a '91 ef sedan Q's
Old Nov 28, 2008 | 01:49 PM
92hondaswap's Avatar
Default B16a on a '91 ef sedan Q's
I just bought a 1991 civic Lx sedan and I just happen to have a jdm B16a engine @ my garage and im thinking of doing a swap wit it, now i like to know what kinda axles i need after i do the swap? or do I need to swap the front brakes to a 90-93 tegs with 90-91 Dx hubs?? i heard if i keep the original teg hubs that it will mess up my suspension...... well i'll appreciate any info on this matter, thanks....
Old Nov 28, 2008 | 01:59 PM
Gold DA9's Avatar
Got to convert to dpfi to mpfi also.
Old Nov 28, 2008 | 02:28 PM
yeah I have a the Stock B16a manifold as well.. I'm pretty sure I have a to get a B-series Vtec ECU and obd1 harness, unless I get a obd0-obd1 conversion if I decide on using a chipped P75 ECU Vtec mod ready....
Old Nov 28, 2008 | 02:29 PM
my main concern is the whole front suspension and axles deal...
Old Nov 28, 2008 | 03:33 PM
88zchatch's Avatar
you are going to want to use 90-93 non ABS axles with your swap. You can use the LX hubs they are the same as DX hubs so you will be fine. Also do a dpfi to mpfi swap and use a pw0 or pr4 ECU and stay obd0. I had to swap rear crossmembers because I didn't have a b-series power steering pump
Old Nov 28, 2008 | 03:55 PM
Gold DA9's Avatar
I got a boomslang dpfi to obd1 mpfi harness, 4 wire o2 sensor and plug and wire to harness, obd1 dizzy plug with wire to harness, obd1 injector clips. You would need obd1 injectors, obd1 dizzy, and obd1 ecu. Let me know if your interested.
Old Nov 30, 2008 | 07:33 PM
Thanks for selling me parts I need, but right now I'm only searching for info and not ready to buy anything right now till after christmas.
Old Nov 30, 2008 | 11:26 PM
mario_pic's Avatar
ps i there is not realy a big diffrence in 90-93 non ABS axles and 90-93 abs axles only thing thay added was a little pop on ring lol u can pop it off and its a non abs shaft after words lol so all he needs is eney 90-93 axle and he will be oke lol
trampuscool
Dec 20, 2010 08:16 AM
chipchip1
Aug 30, 2010 12:46 AM
MEBHB91
Aug 10, 2006 12:09 AM
p3s7
Oct 15, 2003 10:45 AM
Civic_16
Aug 11, 2002 09:00 PM
