Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
high beams not working.
Old Nov 28, 2008 | 12:36 PM
powerwagon340's Avatar
Default high beams not working.
I have noticed that all of a sudden lately my high beams no longer work.
The low beams are still working, but when you click over the high beams you don't get anything. I checked the relay and tried a few others, but that did not solve anything. I got a test light out and the headlight fuses (in the engine bay) both have power when the low beams and high beams are on. The next test i did was to check for power at the headlight sockets... with the low beams on, the left and right pins had power, but not the top one. when i clicked the high beams on, all 3 had power. This made me believe that the headlight was what was bad. But, i bought a new headlight, and replaced it... and am still having the same problem?
I'm wondering if the headlight isnt maybe grounding itself properly, or something... because its really weird and i cant seem to figure it out.
any ideas?
Old Nov 28, 2008 | 03:59 PM
em2power's Avatar
I dont think that it would be the ground, cuz then they wouldnt work at all... But it could be that your assembly has some corrosion in the connector or somethin like dirt... which is what happened to me... and it doesnt work becuase it isnt making contact... But other than that I would have thought maybe the high beam filament burned out, but if you replaced it and it still doesnt work... then im not too sure.... Sorry I couldnt be more help...
Old Nov 28, 2008 | 05:19 PM
yea, I cant see it being the actual connector only because i have juice in all 3 holes when the high beams are on... but for some reason, it doesnt power the lights. I'm just kinda lost since it has juice up to the headlights, but replacing the headlight still didnt fix it.
Old Nov 28, 2008 | 05:30 PM
HONDAPARTSMANMIKE's Avatar
any ideas?
what year is your car because some year civic had a recall for the headlight switch?? was your car in a accident ever?? you shouldnt have power on all three pins you should only have a power and a ground when the low or high beams are on.
Old Nov 28, 2008 | 05:49 PM
The car is a 2003. And the high beams used to work when i first bought the car in February... but it seems like at some point during fire season this summer they stopped working. So what pins should have power when the high beams are on?
I saw the recall for the headlight switch, but that seemed to be only for the low-beams not working.
Old Nov 28, 2008 | 06:18 PM
you should have pwr at the red/yellow wire on driver side and at the red wire on the pass. side when the highbeams are on.
Old Nov 28, 2008 | 06:33 PM
Interesting, when the low beams are on... the Left and Right pins have power...
and when the high beams are switched on... the Left, Right, and Top pins have power...
What am i suppose to have power to when the low beams are on?
the directions I am referring to as left means passenger side, right means driver side.. and top means the top horizontal in the center.
Old Nov 30, 2008 | 11:31 AM
some help?
Old Dec 6, 2008 | 04:20 PM
anyone?
Old Dec 24, 2008 | 01:07 PM
Default Re: high beams not working.
well, it was the headlight switch and i finally replaced it today. pretty simple, only took about 30 minutes.
Kirk Hoey
Sep 28, 2019 11:25 AM
Sgalena
Honda CR-V & Element
Apr 8, 2018 01:50 AM
pr1madona
Oct 1, 2016 11:52 AM
StreetRiot_DRE
Lighting
Mar 6, 2008 11:49 AM
Jacen
Mar 22, 2006 10:51 PM
