crx main relay
ok first off i bout 100% sure its my main relay..
i dont hear the feul pump priming, and i hear 1 click
what is the exact part number from autozone so i can buy it, because they have like 5-8 different relay and i dont know which one i need...
i know honda dealer part number is 39400-sh3-003...
NEED TO KNOW AUTOZONES PART NUMBER ASAP !!!!!!!!!! PLZ HELP
You might not have to buy a new. The typical failure mode is cracked solder joints on the relay's circuit board. If you can, or know someone who can, do a decent job of resoldering the joints, the relay will be as good as new. This of course assumes the internal relay contacts are in good shape. It's a no-cost fix and worth a try. BTW, we're talking rosin core solder and a light duty soldering pencil (stick) here, not a tourch and plumbing solder.
Not true. Ive bought some stuff through these guys. Downest runs the shop if you got $25 this might be your route. http://www.wickedinnovation.net/prod...r-Service.html
autozone does not have the main dizzy listed in their system the best bet would be to take your main relay and find out if they can match it
like stated above the best thing you could do is buy a new oem honda one since there were many tsb about main relays and they re-enginired the main relays so the new ones from honda are your best bet
Don't buy a new one if you can get someone to resolder your existing one. I don't know about you guys buy Honda rape us for parts like that.
just look here, follow the guide and save yourself a few dollars to spend elsewhere.
FWIW, you do not need to remove any solder first. Just reheat the joints until they 'flash' into liquid mode, remove the heat and let cool withiout disturbing anything. If the solder gets sucked away by the pins, you can add new solder. Use the look of the existing joints as a guide to see if you are doing it properly.
CoolRedXylophone
Jan 28, 2006 01:25 PM
