traction control found on JDM ecu's how to bypass?
Old Nov 28, 2008 | 09:11 AM
98greensi's Avatar
Icon6 Cel, 20, 36 help?, jdm traction control and electrical load detector
hello i just picked up my 95 cx hatch with a jdm b16a in it, the previous owner had vtec working and all but now cels 20,21,22 and 36
20 Electrical load detector
21 VTEC spool solenoid valve
22 VTEC pressure valve
36 traction control found on JDM ecu's
-anyways 21,22 are probily due to wires broken on the green plug on the vtec solenoid i tried to fix the wires but nothing changed i guess i failed so i'll to pick one up at a scrap yard
-anyone have a clue what the "Electrical load detector is"?/?
-is there a way to bypass this traction control? beside chipping the ecu, or will the check engine light always be on due to this?
Thanks for any help, Tom
Last edited by 98greensi; Nov 28, 2008 at 12:31 PM. Reason: trying to get more viewers
Old Nov 28, 2008 | 03:42 PM
98greensi's Avatar
Alright so i've searched and searched, I did find some test to determine if the eld is bad. or too find out if it's a wire short or a ground. if you have code 20, did you source the problem or just leave it?. i fixed the pressure switch today (didn't have to much time to work on it), so someone chime in if you dealt with any of these issues,
Old Nov 28, 2008 | 06:53 PM
98greensi's Avatar
Bump for the night hawks
charosenz
Engine Management and Tuning
Oct 12, 2016 11:23 PM
nonvtec92
12
Aug 17, 2009 11:45 AM
0321
May 9, 2006 04:31 PM
brockscivic
Oct 26, 2005 05:34 AM
labatia
Jun 21, 2004 11:52 AM
