price on semi rebuild for b18b
Old Aug 1, 2002 | 01:37 PM
Audi A4's Avatar
Default price on semi rebuild for b18b
just curous on what u guys paid for shops to put in ur rods and pistons. like eagle rods and srp pistons.
Old Aug 1, 2002 | 07:40 PM
OneFastLS's Avatar
Default Re: price on semi rebuild for b18b (DRAG lll INTEGRA)
My brother recently had to have his B18B rebuilt by the dealership because of seized piston rings and major blow-by. The dealership charged him 1,750.00 to put in new pistons and rods, as well as boring out the cylinders and cleaning any dirty parts. This seemed like one hell of a deal to me.
Old Aug 1, 2002 | 08:35 PM
Audi A4's Avatar
Default Re: price on semi rebuild for b18b (OneFastLS)
parts and labor?
Old Aug 9, 2002 | 11:11 PM
mskibbz-T's Avatar
Seem pretty damn cheap... especially coming from a dealership
Old Aug 10, 2002 | 08:11 AM
Audi A4's Avatar
Default Re: price on semi rebuild for b18b (mskibbz)
yeah really. but hey maybe he knew some one.
Old Aug 10, 2002 | 08:21 AM
93LSivic's Avatar
Spend the extra cash for the JE's. You get what you pay for with the SRP's. Do it yourself mang.
Old Aug 10, 2002 | 09:20 AM
lsvtec4door's Avatar
my machinse shop work from labor only was about 700...this included boring the walls .25 over and honing, putting the new rods o the new pistons,micropolish the crank and balance and assemble everything, but remember the 700 dollars didnt include parts
Old Aug 10, 2002 | 10:22 AM
Leimokei's Avatar
New User
pistons JE..$500...$300 for crower rods, replace rod bearings, also..might want to have the crank rebalanced...and replace the bearings, and get new rings...$200
you have to get the machine shop to bore the block so the pistons will fit in..have the shop forge the rods and pistons together...$100 for boring...to install about another $300-$400
Old Aug 10, 2002 | 06:23 PM
93LSivic's Avatar
Default Re: price on semi rebuild for b18b (Leimokei)
You dont want the $300 crower rods--those are crap. You will want the better forged ones.
Old Aug 10, 2002 | 06:26 PM
baonest's Avatar
Default Re: price on semi rebuild for b18b (93LSivic)
3000 for all rebuilt... 11.5:1, 84mm sleeved.
Old Aug 10, 2002 | 07:21 PM
Audi A4's Avatar
Default Re: price on semi rebuild for b18b (baonest)
well i have wiseco pistons 8.5:1 and eagle rods. now i just need the labor.
Old Aug 10, 2002 | 08:41 PM
Ri5e's Avatar
Just do it yourself. It only took me 16 hours with goofing around.
Old Aug 10, 2002 | 09:01 PM
baonest's Avatar
Default Re: price on semi rebuild for b18b (BG Boost)
that'll get the job done..
Old Aug 10, 2002 | 09:14 PM
Mr. Softee's Avatar
i had my block disasemmbled and reassembled for 350$.
sam
Old Aug 10, 2002 | 11:42 PM
Kyoung05's Avatar
Default Re: price on semi rebuild for b18b (94goldjungsr)
Are these prices when you take your entire car to the shop, and they pull/machine the block, replace all bearings, gaskets, etc, install the new pistons/rods, and reassemble? A local machine shop quoted $100 labor to bore out the block to fit larger pistons, but $1500 for the entire job. The $350 you said for disassemmbly and reassembly of your block, did you already pull your engine out of your car? Or did they do everything for you?
Old Aug 11, 2002 | 12:57 AM
mskibbz-T's Avatar
Default Re: price on semi rebuild for b18b (Kyoung05)
Its ~800(more or less, depending on the shop) around Seattle to pull your engine and take it to a machine shop for work and then to install it back in your ride, and you pay the machine shop seperately...
Old Aug 11, 2002 | 01:46 AM
Mr. Softee's Avatar
pull your own engine, its so damn easy.
Her eis waht i did.
Took out engine, took off head / block.
handed them head, handed them block. Had htem bore over 25. Had them vat hte block. had them disassemble / reassemble... then give it back.
It was like 400$ total on the block, including bore / hone / dis/re assembly.
Old Aug 11, 2002 | 06:37 AM
mugenracer's Avatar
i had a top end re-build didnt touch bottom end.
$120 for port/polish and valves re-ground
$240 for head set (seals/gaskets etc)
$180 for piston ring set
$80 for timing belt
$520 for labour
All OEM honda parts
Old Aug 11, 2002 | 09:55 AM
93LSivic's Avatar
Default Re: price on semi rebuild for b18b (mugenracer)
$80 for timing belt
$520 for labour
All OEM honda parts
How's your *** feel after that?
Old Aug 11, 2002 | 10:49 AM
aCuRaLsTuRbO's Avatar
Just do it yourself. It only took me 16 hours with goofing around. that'll get the job done..
Sounds good to me...!
Old Aug 11, 2002 | 10:52 AM
slowerthanu's Avatar
New User
SRP's are made by JE!
Old Aug 11, 2002 | 02:31 PM
mskibbz-T's Avatar
Default Re: price on semi rebuild for b18b (slowerthanu)
Yeah but they aren't JE quality
forbiddenera
Engine Machining & Assembly
Sep 7, 2017 02:11 AM
sik_sol
Dec 29, 2006 08:06 AM
Ben Huynh
Nov 15, 2004 09:57 AM
LagunaSecaEG
Jun 14, 2004 03:38 PM
a1320honda
May 10, 2004 06:55 PM
