91 ACCORD SPEEDO NOT WORKING
Old Nov 27, 2008 | 05:14 PM
AJAUTO's Avatar
Default 91 ACCORD SPEEDO NOT WORKING
SPEEDOMETER HAS BEEN REPLACED,ALSO SPEED SENSOR ,CANNOT GET IT TO WORK,ALSO TEMP GAUGE GOES TO HALF COLD OR HOT? RPMS & SHIFT INDICATOR,GAS GAUGE WORK FINE IT LIGHTS UP
Old Nov 27, 2008 | 08:01 PM
P_Adams's Avatar
Did you replace the entire cluster or just the speedo head?
Does the odometer work?
Temp Gauge yes / no?
P
Old Nov 28, 2008 | 03:43 AM
doubleRdazz's Avatar
if you replaced the entire cluster and the speed sensor then i would have to say that there
is a break in a wire somewhere
was the speed sensor new?
if so then i say break out the electrical manual and start checking wires for continuity
Old Nov 28, 2008 | 06:52 AM
AJAUTO's Avatar
Default 91 honda
i did replace the whole thing and the temp gauge does work but starts off at half
Old Nov 28, 2008 | 09:25 AM
P_Adams's Avatar
You've got an interuption somewhere (open circuit) and it may involve more than one system. I'd recheck the main connector on the back of the Cluster. It's the common point where these systems would use the same connector.
If the VSS was still bad (or any of it's associated connectors), you'd have (most likely) a CEL, and / or a flashing S/D4 indicator, but you don't.
P
Old Nov 28, 2008 | 10:25 AM
turboH22Aakkord's Avatar
P
that was my guess... double check all of your grounds and good luck!
Luillo
Jan 25, 2013 08:44 AM
96honda_EK
11
Oct 20, 2009 03:40 AM
o0ohaviko0o
Apr 1, 2008 07:04 AM
charles1
Jul 22, 2006 09:59 PM
koshie
Oct 26, 2004 02:57 PM
