93 sedan idle problems... Help
i have a 93 civic lx sedan with the D15B7 and every time i start if up the idle shoots up to 2500 - 3000 rpm. Thinking i need to replace the IAC? Is this the issue or anything else i could start with?
https://honda-tech.com/forums/acura-integra-6/%2A%2A%2Ahow-clean%2A%2A%2A-your-iacv-k-idle-air-control-valve-1575913/
and if that doesn't solve it, you may need to clean the FITV
you dont need to replace it, just clean it with some brake cleaner, i have the same problem which im going to fix it this weekend but here is the how to:
https://honda-tech.com/forums/showthread.php?t=1575913
https://honda-tech.com/forums/acura-integra-6/%2A%2A%2A-how-%2A%2A%2A-clean-your-fitv-aka-fast-idle-thermo-valve-1564019/
jefe
16
Oct 25, 2011 07:17 PM
