clutch adjustment??
Old Nov 27, 2008 | 11:21 AM
kerrisaysss's Avatar
Default clutch adjustment??
can i do this myself or would i have to take it somewhere and get it done? : /
Old Nov 27, 2008 | 11:58 AM
AndyD's Avatar
What exactly are you trying to adjust? What's it doing to make you think it needs adjusting?
Old Nov 27, 2008 | 12:01 PM
like my clutch is slipping, like ill be in 5th gear and ill go to accelerate and my rpms will shoot up, everyones telling me i need to see if it can be adjusted before i replace it. but either way im going to replace it but i cant afford it right now so im going to see if i can adjust it or get it adjusted.
Old Nov 27, 2008 | 12:09 PM
AndyD's Avatar
Ah, ok. No, you can't adjust that. It sounds like your clutch is done. The only thing you can adjust is engagement point.
How many miles are on it?
Old Nov 27, 2008 | 12:43 PM
ugh that sucks. : / only like 90k. so its like nothing. but i guess ill just take it tomorrow n get it adjusted.
Old Nov 27, 2008 | 12:51 PM
AndyD's Avatar
If you're planning to have the clutch changed anyway, I wouldn't even bother messing with the engagement point.
Old Nov 27, 2008 | 12:54 PM
yeah. : / i guess theres not much i can do about it right now, other than to get it adjusted and just stick with that until i get a new clutch. but thanks for your help : )
Old Nov 27, 2008 | 01:06 PM
slimjimming6688's Avatar
check your clutch fluid
Old Nov 27, 2008 | 01:29 PM
idk if its that like its the actual clutch slipping..
Old Nov 27, 2008 | 01:39 PM
dagle's Avatar
behind the clutch pedal, you'll see a gold-colored rod. clockwise towards the firewall will raise engagement point, counterclockwise will bring it towards the firewall. remember not to go too crazy on it, as there is a point where the clutch does not engage at all, and there's a point where the clutch doesn't disengage at all.
Old Nov 27, 2008 | 01:41 PM
and that can fix it? like, my rpms will shoot up say when im in 5th gear ill go to accelerate and my rpms rev really high then when i take my foot off the gas and try again itll actually accelerate, that will fix this??
Old Nov 27, 2008 | 01:45 PM
dagle's Avatar
shoot me an AIM if you want some help, i don't quite understand.
Old Nov 27, 2008 | 01:47 PM
TruNinja619's Avatar
I don't think you understand what AndyD is saying. Your clutch disc is gone and there's no adjustment you can make other than the engagement point on the Clutch Master Cylinder rod to clutch pedal. The sooner you get that fix'd, the better, or else you'll find yourself stranded b/c you can't get the car to move.
Old Nov 27, 2008 | 01:52 PM
and whatll that do since my clutch is gone? i know i need to replace it eventually but people have told me that i can adjust it to where itll grab more?
Old Nov 27, 2008 | 01:56 PM
i IM'ed you, sn is kerrisaysss
Old Nov 28, 2008 | 04:14 PM
6gsillyca's Avatar
If your clutch is slipping, there is nothing you can do to "prolong" your clutch life by adjusting it, and there is no adjustments you can do to make it "grab" more
If it is slipping really bad, you should stop driving it, before you leave yourself stranded somewhere.
Old Nov 28, 2008 | 04:53 PM
lrayford's Avatar
yup. u pretty much need a clutch. iv had a few lol. when it starts slipping like that id stop driving it. iv been stranded like that b4. its no fun AND
if u absolutely have to drive it; do it as littel as possiable. and dont dog on it
untill u get ur new clutch and brake it in or its going to fail completly a "faster"
Old Nov 28, 2008 | 08:08 PM
yeah its my DD, so i have to drive it : / im hopefully getting a new clutch this weekend and probably putting it in by tues/wed. but thanks for all the help guys !!
Old Dec 3, 2008 | 09:16 PM
H22Prelude420's Avatar
yea my clutch is pretty much gone and i absolutely had to drive it and yea it was no good i almost got stuck a few times cause it wouldnt go into gear so i had to kill the engine so i could get it into a gear and rev the **** out of it so it would move and slowly get upto speed i.e. 4th gear trying to drive on residential roads and starting of at stop signs and driving on the highway. that **** sucks...now i gotta replace it myself with no mechanic experience and a chilton.. yippee
redman223
Jul 13, 2007 07:19 PM
Kwuaymaikrup
Jan 4, 2003 10:07 AM
sshaikh01
Sep 28, 2002 07:17 PM
LOwrestling2001
May 26, 2002 03:28 AM
AggAccord03
Feb 26, 2002 11:18 PM
