timming belt slippage?
Old Aug 1, 2002 | 11:57 AM
self_made's Avatar
Default timming belt slippage?
SO i was driving to my friends, my car starts to misfire, it had happened to me before a while ago, and it was a loose plug wire...I tightened all of them, didnt work...I changed the plug wire...It got better...then I went to pick up my friend, and everytime I step on it, it starts misfiring, if I dive slowly and dont step on the gas, more than 1/4 down, its all right, so whys is doing this? Im thinking its that the timming belt slipped or something?
Old Aug 1, 2002 | 02:36 PM
tmg's Avatar
tmg
Default Re: timming belt slippage? (VTECNLUDE)
no, it doesn't sound like a missing timing belt. does it only act up during acceleration? it may be your distributor or cap. check your ignition and fuel setup. do you get a cel? what mods do you have or what have you recently changed?
Old Aug 1, 2002 | 08:31 PM
bob01721's Avatar
It could be just about anything from a marginal coil to a dirty fuel filter or clogged injectors. Like themi6group asked, have you changed anything recently?
Doesn't sound like a slipped T-belt, though. If it were, you'd notice it ALL the time.
Old Aug 1, 2002 | 10:03 PM
self_made's Avatar
Default Re: timming belt slippage? (themi6group)
doesnt throw a cel, Im gonna change the cap/rotor tomorrow, gonna check the timing belt, just in case, and I recently put back my stock intake....that has nothing to do with it, but thats all
Old Aug 7, 2002 | 10:13 AM
self_made's Avatar
Default *update*
I changed the fuel pump relay, my pops said it might be that...it worked..for like 6 hours..thenit started doign it agen, but only between 1000 and 2000rpm's when I floor it, I dunno what it could be..maybe the fuel filters a lil dirty, or injectors, anyone have any suggestions?
Old Aug 7, 2002 | 01:33 PM
kinesistech's Avatar
Default Re: *update* (VTECNLUDE)
If your fuel filter is still original, change it. Its old as hell. It is the most neglected filter. Check your plugs. If it looks fouled I would check ignition system. If it looks like its been leaner than normal try fuel system. If the plugs are older than dirt, change those too. Does the car get much in the way of preventative maintenance? If any of these are the cause maybe you should do a service.
Blacktt7
Nov 28, 2007 05:12 PM
NikeSB
Sep 14, 2006 04:23 PM
ham
Aug 2, 2005 05:17 PM
94gsr_vtc
Nov 12, 2004 08:30 AM
nerdish
Jul 17, 2001 11:22 PM
