19" wheels on a 2002 civic coupe
I bought 19" wheels for my civic wich is lowered 2 inches and the touch the rear quarter lip... Anyone done 19's on a civic and can talk about it??? The tire size is 215 35 19... Please send me all the pics and info possible
Cheers Phil
Cheers Phil
I don't feel like running negative camber though wears out tires way to fast... ARGHHHHh lol ... And rolling the fenders the paint will probably crack when i try to do so?!? Is there a trick for the paint not to crack?
You can run negative camber as long as your toe-in stays within spec. I would not recommend rolling your fenders unless you plan on having your 1/4 panels repainted, as it's the only true "proper" way to do it.
The paint will most likely crack.
Being that you insist on running monster truck wheels, you'll most likely have to roll the fenders, as increased negative camber will probably not negate the contact with the rear wheel arch lip.
These "low offsets" and crazy stances you see are done with wheels of fairly minimal size.
here was my car on 17's
and this is one on 19's ( NOT MY CAR )
just like the one with the 19's my rear is a bit lower than the front and that's why she rubs on the back lips but the front clears fine just with sharp turns...
Stickied at the top of this forum is a topic called
Forum Rules and FAQ - READ BEFORE POSTING
It says:
It says:
Originally Posted by Forum Rules and FAQ - READ BEFORE POSTING
7. Bump once and if you still don't get the info you're looking for just let it die, don't bump it again. If you bump the topic a second time, the topic will be locked and you will lose points. Think about this - this means that if you use your single bump on your topic after an hour, when it's still at or near the top of the forum topic list anyway, it will be wasted when it doesn't accomplish anything for you.
