eg/da coilovers/struts on da?
will kyb struts from a eg/dc fit on a da? i know the wieght it about the same on the integras... but how will it affect the ride? they are ground controls with kyb agx struts.
I believe the front fork length is longer on the DA, therefore making the front end sit a bit higher. If you have the ground controls you could probably still use your forks, and just adjust them dowm. The other option would be to use DC/EG forks. Good luck!
