Winter wheel/tire set up...
Winter is real close here in the Northeast. Looking to get a winter set up. Anyone have any suggestions as to good winter tires that fit well on our ITR's? Should i just put on some steelies?
any of the latest "ice" winter tires are great
use steel wheels as mentioned previously if you don't have a spare set
if you have an adjustable suspension -- you might want to raise the car a bit too
here in alaska we can use studs in the tires. which help on the ice. most places cant have them however. ive had good experiences from my bfgoodrich t/a's. grip nice in snow and stop pretty well on ice. bridgestone blizzaks are nice too. pricey.
Im located here in CT. So we get a lot of snow. I looked on tirerack and im looking at getting the Bridgestone Blizzak ws-60. They got good reviews and the ws-50 was a good tire. I dont have any steelies, where can i source some? I thought i remember reading a post a while back with nsxtasty mentioning that there is an option on tirerack where you can purchase the tires with steel wheels, but i cant seem to find that package???
You can source steelies from wreckers and or Honda.
97-00 CR-V Steelies aren't that expensive and can be found easily.
06-08 Civic steelies 15" is alittle more difficult to find and pricier.
I think some tire shops have "Honda" replica steelies for cheap too.
one of my friends has some old 02 rsx wheels, that he still has after he sold his car. The sizes are 16in, tirerack says 205/55-16, the ITR is 195/55-15? Can these rsx wheels fit?
Discount Tire Direct has 15" steel wheels available for the ITR for $60 each. Their website only shows packages for the Hankook winter tire, but they also sell the Michelin X-Ice Xi2 in 195/55-15 ($104/tire), which means you could put together a wheel and tire package for $656 shipped. When comparing prices, remember that Discount Tire Direct offers free shipping, and the savings on shipping offsets their higher prices. (If the website doesn't allow you to put together that combination, you may need to phone them.)
The X-Ice Xi2 and the WS-60 are the two best studless winter tires you can get. The X-Ice Xi2 actually beat the WS-60 in snow and ice testing (click here).
All-season tires are a good choice for winter use only in areas that don't get a lot of snow (yes, KC, also say Virginia or Oklahoma) and for people in colder areas who must use the same tires all year round and are willing to accept the compromise involved.
If you live in an area that gets a fair amount of snow and frigid cold, such as New York or especially snowy cities like Boston, Toronto, Montreal, Detroit, Chicago, and Minneapolis, then you're better off getting some real winter tires for winter use.
If it were my car, I'd either find some used 15" wheels that fit - steelies or CRV wheels or whatever - or I'd get a wheel and tire package from Discount Tire Direct or the Tire Rack. Given the tire availability, I don't think 16" is the way to go.
Studies have shown that in most winter conditions (including ice), today's better "studless" winter tires, like the Blizzak WS-60 and the Michelin X-Ice Xi2, actually grip better than studdable tires with studs installed. If you're interested in reading a test done comparing studded and studless winter tires, you can do so here:
AN OVERVIEW OF STUDDED AND STUDLESS TIRE TRACTION AND SAFETY
Here are some of its conclusions:
Originally Posted by AN OVERVIEW OF STUDDED AND STUDLESS TIRE TRACTION AND SAFETY
1. Studded tires produce their best traction on snow or ice near the freezing mark and lose proportionately more of their tractive ability at lower temperatures than do studless or all-season tires.
2. The traction of studded tires is slightly superior to studless tires only under an ever-narrowing set of circumstances. With less aggressive (lightweight) studs being mandated, and with the advent of the new “studless” tire, such as the Blizzak, since the early 1990s, the traction benefit for studded tires is primarily evident on clear ice near the freezing mark, a condition whose occurrence is limited. For the majority of test results reviewed for snow, and for ice at lower temperatures, studded tires performed as well as or worse than the Blizzak tire. For those conditions in which studded tires provided better traction than studless tires, the increment usually was small.
3. The precise environmental conditions under which studded tires provide a traction benefit are relatively rare. The maximum frictional gain (in comparison to nonstudded (not studless) tires) is found for new studded tires on smooth ice, where they have been shown to provide up to 100 percent gain in certain tests. However, the relative frictional gain of studded tires diminishes or becomes negative on roughened ice, as the temperature drops, as the studs wear, or if the comparison is made with studless tires.
Another option is to try and find a nice cheap set of 15" ITR wheels. sometimes you can come across a bargain if you look on craigslist or maybe even ebay. i lucked out at my local wrecker with a set of white 15"s. They clear Spoon calipers without any spacers too if you decide to buy those oneday or if you already have them (which i don't think steelies will without a spacer).
I'm using the Bridgestone Blizzak WS-50 in 195/55/15 size and they're amazing tires in the snow. It doesn't snow much here in Vancouver, but when it does, i'm glad i have them. The Bridestone tires do tend to wear quickly though so i wouldn't milk them on the dry roads for too long. Prepare for some squirmy feeling handling as well.
Also, when i was at Acura, we had some 15" 5-lug steelies in the shop that were labelled as 'RSX take-off' wheels. I'm not 100% sure about this, but perhaps the base model RSX with the hubcaps was a 15" as well? it's a black steelie with many holes (doesn't look anything like the CRV steelie). The CRV steelies work with stock calipers without any issues, btw.
I have a 10 years old set of winter tires steely package from tire rack sitting in my garage for my previous 97 CW R with 205-50-15 Winter Pirelli which did great job during the days when I only own one vehicle.
Unfortunately, you may currently have availability issues when looking for Michelin snow tires. Most of them went to Canada when Quebec instated the new winter tire law. I know Tire Rack has some, but I would definitely look for them locally first though.
It's quite common for tire dealers like the Tire Rack to run low on availability of winter tires as you get into winter. They usually have plenty of options in October-November, but by the time you're into January, available choices have dwindled.
shameless plug: I've got a set of black sportmax 002 wheels with chrome lip that i'd be willing to sell for reasonably cheap if anyone's interested... just let me know. they'd be far better to use then ugly-*** steelies. the only reason why i'm not using them and i'm using my steelies is because i just don't want to pay the 50 bucks to swap the tires over.
I have a set of 15 inch steelies w/ Dunlop DS1 winter tires that I used on my ITR. They were a package from Tirerack a few years back. Tires are 205/55/15 which do fit just rub only at full lock w/ stock height.
They work great here in the Northeast if your out and about. I used to outrun any 4x4 w/ ease. Just had to watch for snow embankments.
They are for sale if interested. I will no longer be using the R during winter.
howabout you dont drive your car during winter .. its really dangerous.. you can be the best driver in the world but not everyone knows how to drive their cars in winter. i regreat driving my car last winter i almost got hit 5 times
Good thing I read this post or else I wouldn't know what to do, 06-09 Civic and 97-01 CR-V steelies are backordered for Canada.
giff74
Apr 22, 2005 02:29 PM
