All motor h22 accord or boost
Old Nov 26, 2008 | 10:25 AM
Teddieb15's Avatar
Default All motor h22 accord or boost
I want to get my car to break into the 13.My last run was a 14.5. I was thinking that if i get good traction and get aleast 210whp I should be able to to do this. As of now i have 188whp. Would it be wise to continue with this or to get a turbo and put it on the stock motor.
Old Nov 26, 2008 | 10:42 AM
EmminoDaGreat's Avatar
Boost is better :D
Old Nov 26, 2008 | 11:29 AM
98vtec's Avatar
moderator emeritus
if all you are wanting to do is run 13's then stay all motor. If you are wanting to go faster than that, its going to take a lot more money to do it NA than it would boost, however, a properly built NA engine will likely last longer than a stock motor with boost trying to go faster than 13's. If you build the motor for boost + turbo kit, plan on spending more than an NA build.
Old Nov 26, 2008 | 01:59 PM
Brad_and_the_acc's Avatar
What is your setup now? 188hp, please be specific.
Old Nov 26, 2008 | 02:29 PM
erk89's Avatar
What upgrades have you added?
Old Nov 26, 2008 | 03:50 PM
P_Adams's Avatar
It's the power to weight ratio that your looking for
Shed as much weight as you can, It's a lot cheaper.
Yeh, let us know what you've done so far. Maybe there's something to be done yet...
Accords: I love 'em. But often it's more like "The Fat and the Furious" for the amount of weight it has to haul around.
P
Old Nov 26, 2008 | 09:56 PM
boostedhks's Avatar
P
Hahahahahaha mad funny hahahah! idk what is it about accords tho but i like it better than a civic, when you go in an accord and in a civic (both 97) u do feel the difference, in the accord u feel that u are more in a real car than in a toy car but the civic its like so simple that it makes me feel like if its just a toy car or something :X IDK, but even tho they are heavier they are way more comfortable than a civic :X to my opinion...
Old Nov 27, 2008 | 12:26 AM
thesonners's Avatar
boost. fully gutted with M&H slicks
Old Nov 27, 2008 | 08:43 PM
scanlessfool's Avatar
I'm sure there are members here who can easily help you but you do need to provide specifics. If anything go over to the CD squad thread and you'll DEFINETLY find all the info you need from VERY knowledgable people.
Old Nov 27, 2008 | 09:21 PM
98vtec's Avatar
moderator emeritus
it would be nice to know what your mods are right now so we have an idea of where you stand at the moment.
Old Nov 30, 2008 | 04:11 PM
Teddieb15's Avatar
h22a, i/h/e, skunk2 cam gears, skunk2 intake manifold, hondata s200 tuned by JE importperformance.
mM not sure if i do want to go boost. Also i have never seen a all motor 94 accord
Old Nov 30, 2008 | 04:20 PM
katzenjammer84's Avatar
There's a guy on another Honda forum that has a 13.9 second all motor H22A4 Accord. It's a 1994 DX Sedan, full interior, but he's spent untolds amount of money getting it to that point, and short of a stroker kit it's pretty much maxxed out.
I'm no H22 expert, but I know that sleeving is pretty much a must on the H22 on anything other than light boost due to the thin sleeves.
Eitherway, you're looking at money.
Old Nov 30, 2008 | 04:31 PM
Teddieb15's Avatar
What forum is he on
Old Dec 3, 2008 | 04:46 PM
ALLxMOTOR EG's Avatar
Vietnamese!
NA!!!!
Old Dec 3, 2008 | 11:44 PM
TreWatts's Avatar
the **** you have + p&p + nice cams + weight reduction should do ya.
friend of mine has that setup tuned on an s200
..then again, he is in a much lighter prelude and drives like a champ.
Old Dec 4, 2008 | 01:59 AM
GhostAccord's Avatar
N/A is the only way......
Old Dec 4, 2008 | 07:01 AM
vic_anite's Avatar
Default H22 All motor/ Boost ANSWER!
Boosting an H22 engine (stock) will only allow 6 psi with out blowing a piston ring or worse. (beats the whole idea of putting turbo in your vehicle) If you still decide to go boost, Get the block sleeved, then you can run a higher psi.
Working on H22 and H23 engines for 2 years now. Best bet is all motor.
http://s374.photobucket.com/albums/o...t=b1e2f45c.pbr
<embed width="448" height="361" type="application/x-shockwave-flash" wmode="transparent" src="http://i374.photobucket.com/remix/player.swf?videoURL=http%3A%2F%2Fvid374.photobucke t.com%2Falbums%2Foo184%2Flocalvic%2Fb1e2f45c.pbr&a mp;hostname=stream374.photobucket.com">
Old Dec 4, 2008 | 09:40 AM
flight50's Avatar
h22 are made of frm material or frp something like that. anyways the sleeves aren't so much of the the problem. its the pistons. they can't take the pressure. its been argueed over and over what give on a stock motor when boosting. from the pistons, to the ringlands, to the block, the cams. mahle makes piston different compression pistons that are made to work with a stock h22 and you don't have to resleeve. now if your going higher than lets say 12psi, then yeah your better off re-sleeving. the key will be your tuning though. if you have access to a great tuner, see what they are comfortable with as far as limits. if you have a med to low quality tuner, leave room for error for your tuning. an accord will always be heavier than a civic. all motor accords will take loads of money if your trying to be time. if you do hit your time mark, you'll get thirsty for more power and you should have boosted instead. as metioned power to weight ratio is huge. don't under estimate it
h22 all motor civic>h22 all motor accord.
efnitup4life
Jan 22, 2011 01:04 PM
1990hondaHF
Nov 29, 2010 05:15 AM
power11
Jun 10, 2007 06:47 PM
Slick GS-R
Mar 22, 2002 04:12 PM
