Which wiring harness??
New to hondas! I have a 1993 civic hb that I am putting a b18a out of a 1991 integra. The question is which engine wiring harness do I use? I have the one from the integra. The one that was on the civic motor went with the engine I sold. Please let me know which I need. Hope it is the one I have.
Thanks
Mac
Thanks
Mac
typically you want to use the harness that is from the car and work the motor in. WhenI did my swap, I kept the old motor as I needed little things like, connectors and brackets off the old motor...it helped to have it around..good luck with the swap!
you will need 92-95 civic engine harness and 94-95 integra dizzy, 94-01 integra shift linkage ,axles , half shaft, 92-01 hydro b-series tranny, obd1 ls ecu, 92-01 b or d-series injectors
you dont need a alternator
and what model civic you have? cx, dx, si
slammedef06
Dec 29, 2005 10:42 AM
