Suspension & Brakes Theory, alignment, spring rates....
camber kits
Old Nov 26, 2008 | 12:07 AM
tsgeekz's Avatar
Default camber kits
so i've been hearing that the rear camber kits are the same length as the stock one which mean the aftermarket ones are meant to straighten out the wheel. which (brand) camber kit would actually give you a negative camber for the 96-00 civic hatches? anyone heard about this or am i trippin?
Old Nov 26, 2008 | 03:22 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
How much camber do you need in the rear? The rear wheels' camber curve for 6th gen Civics is already pretty aggressive, more so than 5th gen Civics or 3rd gen Integras. I think for a given drop amount, you end up with more negative camber in the rear than in the front on 6th gen Civics, while it's the other way around on the other cars.
Old Nov 26, 2008 | 03:35 AM
HondachrisEJ1's Avatar
skunk2, omni power both make an adjustable kit i believe for 6th gen. but I could be wrong. when you lower your car you are going to actually going to increase camber and toe at the back. how much camber were you looking for out of the rear? I don't suggest anything more then 3 degrees negative in the rear.
kryptic
Aug 18, 2006 12:25 AM
COMplex.
Honda Civic (2006 - 2015)
14
May 15, 2006 10:47 PM
stmotorsports
Jun 11, 2004 11:55 AM
LUVJDMH22
Oct 10, 2003 09:44 AM
Immortal23
Jul 25, 2001 02:50 PM
