tranny
the DOHC ZC transmission will not work on your D15 unless you get custom axles made for it - the DOHC ZC transmission uses an intermendiate shaft and larger Integra type axles - the inner CV joints on the axles for the ZC are larger diameter with 27 splines - the stock axles are smaller with 25 splines and are to small to fit in the transmission - the ZC intermediate shaft can't be used as the D15 block has no place to bolt the shaft onto
