Performance General Performance oriented Parts (Ex: Camshafts, Electronics, Air Intakes, Exhausts, complete engines)
Skunk2 Racing sale, all Skunk on sale now
Old Nov 25, 2008 | 05:35 PM
Honda Gen's Avatar
Default Skunk2 Racing sale, all Skunk on sale now
on sale now
Skunk2 Pro-Series high performance coilovers are especially designed using state-of-the-art technology to make your road racing and drag racing experience memorable. Skunk2 Pro-Series is the result of high-end testing and employing a rich suspension-tuning experience to the coilovers. And the ultimate result is achieved in the form of spirited performance driving. Featuring shortened shock bodies and shortened shaft strokes for maintenance of suspension travel on lowered vehicles, Skunk2 Pro-Series offers a rare opportunity for the drivers to quickly and precisely set ride heights and corner weights. These special features enhance the vehicle’s capability to handle response, corner ability, stability, and balance. Available in Skunk nonadjustable dual-tube PRO-S design, or Skunk PRO-C adjustable mono-tube design, the Skunk2 Pro-Series Coilover kit includes hard-anodized CNC-machined forged 6061-T6 spring perches, and Skunk2 CNC-wound racing springs made from SAE9254V spring steel.
Skunk2 Coilovers
Skunk2 Pro-Series Racing Cams are proven performers and have earned rave reviews from the experts. Designed to optimize mid-range and top-end horsepower and torque, Skunk2 Racing Cams feature seamless VTEC crossover that allows for the broadest possible powerband. Its high standards of manufacture and performance mean that its competitors are nowhere near to it in terms of popularity.
Skunk2 Cam Gear
Skunk2 Camshafts are a perfect ally for your vehicle that ensures increased horsepower and torque by retaining factory idle quality and low-speed emissions. These camshafts feature a dramatic VTEC crossover from primary to secondary. Some of the other Skunk2 Camshafts also utilize Fast Ramp and Amax Technology that enables the engine to generate extra torque at even lower RPMs. The Tuner Series camshafts lay increased stress on idle quality and emissions rather than the aggressive look that is provided by the Pro-Series camshafts. However, both the Series use high quality cores and are ground on the same CNC cam-grinding machines equipped with CBN-grinding wheels. Perfect for both daily street driven and racing engines, Skunk2 Camshafts offer value for money for every vehicle.
Skunk2 camshaft
Skunk2 Racing Pro-Series Intake Manifold is your best bet if increasing horsepower is the main objective. It improves airflow, which increases the horsepower by up to 8% over stock manifolds on stock engines. Its performance is even better in case of modified or forced-induction engines. Skunk2 Racing Pro-Series Intake Manifold has revolutionized the manifolds engineering with significant horsepower increase between 3000-8800 rpm, which is the broadest power-band increase in the industry. The all-new Skunk Pro-Series is a marked improvement over its previous versions. With accelerated airflow and peculiar design, which increases the effects of wave scavenging at the engine’s optimum operating RPM range, the Skunk2 Racing Pro-Series Intake Manifold manages 22% increase in power over its predecessors. Each runner entry is also modified to balance airflow between cylinders. Skunk2 manifolds have modified IAC opening on the flange, which allows the use of oversized throttle bodies. Skunk2 manifolds are shell-molded and CNC-machined, which gives them superior strength, high-quality finish, and a precise fit. To ensure highest standards and safety, each manifold is vacuum tested. Skunk2 Racing Pro-Series Intake Manifold is ideal for NA and forced induction, and uses all stock sensors and auxiliaries for a simple bolt-on installation for maximum power.
Skunk2 intake manifold
Skunk2 Valvetrain Components are made to undergo extensive in-house testing before they are approved for sale in the market. To achieve top-end performance gains, the Skunk2 Valvetrain Components are tested in engines, both on the dyno and on the road. The design and reliability of these Valvetrain Components is unmatched due to the use of only the best materials available in the market in their development. Available in both Tuner and Pro Series, Skunk2 Valvetrain Components are standard equipments that can be used on all the project cars and racecars we build and support.
Skunk2 retainer
Megan racing turbo Manifold
Megan Racing turbo outlet
Tanabe Downpipe
Invidia Downpipe
Old Nov 25, 2008 | 06:57 PM
Honda Gen's Avatar
Skunk2 valve
Skunk2 Pro-Series Valve Springs are unmatched in quality and performance in the sport compact market. Specifically designed to handle the demands of extreme lift camshafts running at continuous high RPM of professional championship level racing cars, the Skunk2 Pro-Series Valve Springs are proven performers up to 11,000 RPM. One of the striking features of Skunk2 Pro-Series Valve Springs is the use of Japanese-milled super clean chrome silicone wire, which is 100% eddy-current inspected before coiling. The process is fairly simple but executed at higher levels of precision. After coiling, the spring is heat-treated, shot-peened, and empowered with an advanced proprietary chemical polishing and nitriding process. The final output is the Skunk2 Pro-Series Valve Spring that can easily accommodate high lifts and resist the load-loss even under extreme operating conditions. This peculiar, but perfected, process ensures maximum performance by using lesser coils. The Skunk2 Pro-Series Valve Spring is the only valve spring that is dedicated to be used with Skunk2 Pro-Series camshafts.
Skunk2 valve Springs
Old Nov 25, 2008 | 09:09 PM
Mr. Lucky's Avatar
i see the post and specs. but where are the prices?
Old Nov 25, 2008 | 10:05 PM
keepinitrehaal's Avatar
you can see prices when you click the link.
Old Nov 25, 2008 | 10:38 PM
Honda Gen's Avatar
yes just click on the link for price, thank you
Old Nov 28, 2008 | 06:33 PM
Honda Gen's Avatar
bump all order shipped
Old Dec 1, 2008 | 11:42 PM
Honda Gen's Avatar
Old Dec 2, 2008 | 12:26 AM
Honda Gen's Avatar
bump
Old Dec 2, 2008 | 01:18 AM
eg_h22a's Avatar
hey d you have any skunk2 70mm throttle bodies in stock ??? h22a????
thanks if so how much???
thanks
Old Dec 3, 2008 | 12:31 AM
Honda Gen's Avatar
Blox Racing intake manifold on sale also
BLOX Racing Intake Manifold
Old Dec 4, 2008 | 01:39 AM
Honda Gen's Avatar
bump all order shipped Thanks guys
Old Dec 6, 2008 | 03:29 PM
Honda Gen's Avatar
Honda performance parts on sale now
Honda Prelude performance parts
Honda Fit performance parts
Honda Accord performance parts
Honda S2000 performance parts
06+ Honda Civic Performance
Honda Polit Performance
Old Dec 9, 2008 | 02:29 AM
Honda Gen's Avatar
Bump all order Shipped thanks
Old Dec 12, 2008 | 01:45 AM
Honda Gen's Avatar
on sale now
Tokico Blue HP Shock Strut
Tokico Illumina 5 way Shock Struts
Old Dec 15, 2008 | 10:06 PM
Honda Gen's Avatar
bump
Old Dec 18, 2008 | 03:27 AM
Honda Gen's Avatar
Old Dec 19, 2008 | 02:25 PM
Honda Gen's Avatar
bump
Old Dec 22, 2008 | 05:37 PM
Honda Gen's Avatar
Default Re: Skunk2 Racing sale, all Skunk on sale now
bump
Old Dec 28, 2008 | 09:29 PM
Honda Gen's Avatar
bump
Old Jan 2, 2009 | 10:09 PM
Honda Gen's Avatar
bump
Old Jan 7, 2009 | 05:09 PM
Honda Gen's Avatar
keep those order coming
Old Jan 8, 2009 | 12:44 AM
Honda Gen's Avatar
Old Jan 8, 2009 | 10:59 PM
Honda Gen's Avatar
bump
Old Jan 9, 2009 | 05:55 PM
Honda Gen's Avatar
Bump please take a look at our Honda parts list
Honda performance Parts
Old Jan 10, 2009 | 09:20 AM
Honda Gen's Avatar
bump
