99 Accord Air/Fuel Problem
The car runs and idles rough. Dealer came up with code P1164 which is covered under TSB 00-046. They want to replace the O2 sensor and the ECM for $1500. Anyone know of a cheaper work around/repair?
P
I have only seen this one other time and they wanted to replace the computer then too.
That was on a 2000 Insight back in 2002. They did not mention a TSB back then.
It may be a factual repair but maybe you could put an OEM O2 sensor in and then opt for a computer if the issue does not clear up, so be prepared to fork out some bucks.
