Wheels, Tires, Brakes, and Suspension Wheel, Tire, Brake and Suspension Parts (Wheels, Tires, Coilovers, Lug Nuts, Camber Kits, Rim/Tire Tools)
TASAuto.com 10% Off Sale 12/2/08
Old Nov 25, 2008 | 11:07 AM
TASAuto.com's Avatar
Banned
Default TASAuto.com 10% Off Sale 12/2/08
With the holiday season upon us, it's time to give your friends and family your T.A.S. Auto wish list. T.A.S. Auto offers you the best aftermarket and OEM Accord parts and it will all be 10% off on 12/2/08.
Offer valid from 12am - 11:59pm Eastern Standard Time on 12/2/08 only. No other discounts or promotions may be applied. Discount will be automatically applied to your shopping cart during the checkout process. Discount does not apply to core charges, gift certificates or shipping charges.
Save 10% on all parts including these great new items
90-97 2/4dr 4cyl 11" BIG BRAKE KIT
As you increase your Accord's performance, the stock brakes quickly become inadequate. You can now replace your 10" factory rotors and improve braking while still being able to use the 15" factory wheels. This TASPRO kit includes two 11" rotors, two wagon/v6 calipers with brackets, Carbomet brake pads and the proper brake pad clips. The wagon/V6 calipers use a larger piston for increased stopping power while retaining factory reliability. For use with 15" or larger wheels.
Part #194001 Regular Price:$299.95 Save 10% During The Sale
90-97 2/4dr 4cyl 11" CROSS-DRILLED BIG BRAKE KIT
This TASPRO kit includes two 11" cross-drilled rotors, two wagon/v6 calipers with brackets, Carbomet brake pads and the proper brake pad clips. The wagon/V6 calipers use a larger piston for increased stopping power while retaining factory reliability. For use with 15" or larger wheels.
Part #194002 Regular Price:$349.95 Save 10% During The Sale
90-97 2/4dr 4cyl 11" ROT0R-OVER-HUB BIG BRAKE
Combine the stopping power of our 11" Big Brake Kit with the practicality of or Rotor-Over-Hub kit in this amazing package. This TASPRO kit includes two 11" rotors, two pressed bearings and hubs, two wagon/v6 calipers and brackets, Carbomet brake pads and the proper brake pad clips. The wagon/V6 calipers use a larger piston for increased stopping power while retaining factory reliability. For use with 15" or larger wheels.
Part #194003 Regular Price:$599.95 Save 10% During The Sale
90-97 2/4dr 4cyl 11" ROT0R-OVER-HUB DRILLED BIG BRAKE KIT
This TASPRO kit includes two 11" cross-drilled rotors, two pressed bearings and hubs, two wagon/v6 calipers and brackets, Carbomet brake pads and the proper brake pad clips. The wagon/V6 calipers use a larger piston for increased stopping power while retaining factory reliability. For use with 15" or larger wheels.
Part #194004 Regular Price:$649.95 Save 10% During The Sale
90-02 BLOX THROTTLE POSITION SENSOR (TPS)
It is easy to damage a TPS when you are working on your engine and replacements are not available through Honda. Blox Racing has produced this direct replacement for your F or H series motors.
Part #500400 Regular Price:$49.95 Save 10% During The Sale
94-97 4cyl MISHIMOTO RADIATOR
An ideal upgrade to the stock OEM radiator, the Mishimoto aluminum radiator will give your Accord a cooler, more efficient running engine. Manual transmissions only.
Part #499497 Regular Price:$234.95 Save 10% During The Sale
90-02 4cyl TASPRO HYBRID INTAKEs
Our new line of TASPRO HYBRID intakes combine the best of both worlds; all the performance of a high flow aftermarket intake without the high-pitch whistle of an open element filter. Kits include a 3" polished intake pipe, K&N drop in filter and all the clamps and hoses necessary for installation.
Regular Price:$79.95 Save 10% During The Sale
94-97 4cyl RACE STYLE FUEL FEED LINES
These race style fuel feed lines replace the factory rubber hose that runs from the top of your fuel filter up to the fuel rail. Uses -6 AN line. Available in 2 styles.
Regular Priced From $59.95 Save 10% During The Sale
90-97 TASPRO UPPER RADIATOR SUPPORT BRACKETS
Securely hold your radiator in place while adding some style under your hood with TASPRO's upper radiator support bracket. Each bracket is precision cut from aluminum and powder coated in a silver finish. New stainless steel hardware included. Click "Enlarge Image" to view installed.
Part #191600 Regular Price:$39.95 Save 10% During The Sale
Old Nov 26, 2008 | 11:31 AM
Banned
Sale is on Tuesday! Get your wish lists ready!
Old Dec 2, 2008 | 04:04 AM
Banned
sale is today!
xbabysharkx
Southern California
Dec 12, 2014 12:12 PM
TASAuto.com
Dec 2, 2008 04:04 AM
TASAuto.com
Performance
scientisthonda
Dec 6, 2004 07:27 PM
TYPEROLLER#420
Jun 7, 2004 04:07 PM
