B18B swap wont start!
Old Nov 25, 2008 | 10:41 AM
InTheLBC20's Avatar
Default B18B swap wont start!
I swapped my motor in last night and went to crank it and it just turns and turns with no spark. I changed distributor, checked all grounds and fuses, and still nothing. Anybody know what's going on?
Old Nov 25, 2008 | 12:06 PM
InTheLBC20's Avatar
anyone?
Old Nov 25, 2008 | 12:32 PM
honda_hackett's Avatar
umm same probably with me and it was the small ground below dizzy... is you fuel pump engaging when you turn the key?
Old Nov 25, 2008 | 02:44 PM
Groovinator's Avatar
Sounds like a bad ground to me.
The ground right under the Dizzy always gets me. and like the above poster asked, is your furl pump priming? if not sounds like a main relay has bit the dust.
matmcg
Feb 17, 2008 03:34 PM
Scud
16
Jan 18, 2008 03:15 PM
3 G's
20
Dec 4, 2004 08:23 AM
civicrtype
Feb 26, 2003 04:22 PM
