Traction Bar/Sway Bar
Old Nov 25, 2008 | 08:29 AM
SSGojeta's Avatar
Default Traction Bar/Sway Bar
From what i can tell both a Traction Bar and a Sway bar do just about the same thing. but my question is which is better? Or is it possible just to have both on one car?
Old Nov 25, 2008 | 10:27 AM
Tyson's Avatar
they have NOTHING to do with each other.
nothing.
Old Nov 25, 2008 | 10:32 AM
EFstyle's Avatar
nothing.
lol!
Old Nov 25, 2008 | 11:25 AM
BigDare23's Avatar
LOL
Old Nov 25, 2008 | 12:53 PM
ComeOnKip's Avatar
From: Where the wild things are in, NY, United States of America
nothing.
QFT.
Old Nov 25, 2008 | 01:11 PM
0ne-Cam's Avatar
dawg can u use the search???? traction bar is obviously for traction but thats only if u have a turbo/supercharged motor and have alot of tire hop, sway bar in other case is just to keep your chassy from not bending/moving.. yeah i dont know how to spell that so sue me
Old Nov 25, 2008 | 01:14 PM
acmoc's Avatar
a traction bar is to stop wheel hop and give you better 60 foot times, a sway bar is more for going around corners and such, I'm pretty sure you can use both, the sway bar just replaces the stock one and the traction bar. As far as I've seen can replace your crossmember and radius rods. That's the kind I've been looking for, but can only find innovative mounts, and it hangs too low so I'm looking for another that works in the same way.
Old Nov 25, 2008 | 01:45 PM
peter_b16's Avatar
traction bars gives you more power up top and a sway bar allows your car to brake faster...ive seen people have them on at the same time..it can be done only if you are mechanically inclined..
Old Nov 25, 2008 | 01:52 PM
Tyson's Avatar
seriously, is this the new honda-tech?
Old Nov 25, 2008 | 02:16 PM
ComeOnKip's Avatar
YOU HAVE ABSOLUTELY NO IDEA WHAT YOU'RE TALKING ABOUT. STOP IT, YOU ARE NOT FOOLING ANYONE.
I believe it is... 'dawg'.
What happened to an intelligent sharing of ideas? Must have went out the door with zeroforum
Old Nov 25, 2008 | 09:05 PM
CrazyFNG's Avatar
Icon2
WTF
Old Nov 25, 2008 | 09:14 PM
red_EF9Si's Avatar
wow, so much mis-information in this thread. some people should just not post at all instead of making complete asses of themselves.
Old Nov 25, 2008 | 09:29 PM
sgallagher's Avatar
A sway bar links chassis or subframe to both sides of the suspension and will increase the amount of effort necessary for the suspension to move when cornering. Counter acting effect from one side to the other. usually will attach to the lower control arm or to the spindle/knuckle assembly(most honda's connect to the lca).
A traction bar which is normally used on a honda is a front subframe assembly with radius rods connecting to the lower control arm preventing the control arms moving in a rearward or frontward direction.
Therefore 2 completely different components which can be used in conjunction with each other.
The ED/EF Honda already has a "traction bar" setup built into the design. It is often changed out for an aftermarket unit due to the flexing of the rubber bushings in the stock unit or for clearance for engine swaps.
Old Nov 26, 2008 | 12:22 PM
CrazyFNG's Avatar
X2 Theres your answer.
tdhjrh
Apr 5, 2017 05:58 AM
ilvi3tkidxx
Feb 27, 2009 01:24 AM
energ3tic2
Northern California (Sales)
Apr 17, 2007 12:53 PM
2000Pimpinex
Suspension & Brakes
Apr 5, 2005 05:52 PM
