help on 1997 prelude
hey guys I need some help on a prelude im working on, I mostly workin on civics but anyway. this car has a jdm motor and trans, bunch of msd ignition and an intake manifold. its running off of and obdII type R ecu. its got no speedo changed the vss and cluster. I also tried to put a scanner on it and nothing. Is there anyway to jump a plug to make the cel flash like you can on eg's??? any help would be greatly apperciated
yeah its got a p73 in it....Ive got a problem that I hope someone can help me diagnose... the vss isnt working and its got a 12v source and the ground is good, but Ive read the manual from honda and it says that the blue/white wire needs five or more volts, and im gettin 4.76volts...would that make the speedo not work and also what would cause that voltage drop?
