keep low beams on at same time as high beam?
Old Nov 24, 2008 | 06:34 PM
93formula's Avatar
Default keep low beams on at same time as high beam?
is there a simple way to do this? i want to be able to keep my low beams on when i turn on my high beams.
currently im using aftermarket glass housing headlights, the low beams are projectors and the high beams are a reflector housing. ill be using yellow 3000k hid for the low beams and want to be able to turn on the high beams at the same time if i had to. havent decided if ill stick hid's in the high beams yet though.
so if anyone can offer a solution that would be great, thanks.
Old Nov 24, 2008 | 06:58 PM
acmoc's Avatar
Mine already do that, 9006 turn on with low beams. 006 and 9005 turn on with high beams
Old Nov 24, 2008 | 06:59 PM
Crx Jimmy's Avatar
they work like that already, confused
Old Nov 24, 2008 | 07:01 PM
93formula's Avatar
sorry its been so long that i fired up the car i may have forgotten, i was under the assumption that the lows turn off when the highs turn on, my impala does that, lol.
Old Nov 24, 2008 | 07:25 PM
acmoc's Avatar
are they not doing that?
Old Nov 24, 2008 | 08:47 PM
lunalink's Avatar
low beams always stay on even when you turn the high beams on.. confused? is your wiring o.k? lol..
Old Nov 24, 2008 | 11:52 PM
91DBSexyTime's Avatar
ur impala shuts off the low beams beacuse the bulb is a low and high beam in one bulb. EF uses seperate bulbs for low and high beam unless you use one peace head lights, then you wire the high and low wires together and us a H3 bulb or something like that, correct me if im wrong.
James_Starks
21
Oct 16, 2022 12:23 PM
Spartan500
Sep 6, 2007 06:07 PM
harley06
Mar 30, 2007 06:14 PM
inane
11
Oct 25, 2004 06:40 PM
tekstyle
Aug 18, 2004 02:04 PM
