Bogging/Sputtering
Old Nov 24, 2008 | 06:21 PM
213374U's Avatar
0x5359-0055
Community Builder
Icon6 Bogging/Sputtering
Just today my car started bogging down. F22B1 with bolt-ons. Only does it under heavy acceleration (more than 35% throttle) with rpm's under 2500. Soon as I pass that 2500 mark, smooth. That said, I can get out and romp on it and she'll never skip a beat. But if I want to speed up to pass without downshifting, fuct.
Been doing research but none of the OP's were ever very specific. Leads me to believe the fuel filter is at fault?
Anyone with insight would be appreciated.
Old Nov 24, 2008 | 06:25 PM
213374U's Avatar
0x5359-0055
Community Builder
And I just cleaned my EGR ports 2 months ago.
Old Nov 25, 2008 | 09:40 AM
213374U's Avatar
0x5359-0055
Community Builder
Nobody huh? The thing that bothers me, day before yesterday when this began, I had detailed the car inside and out. Hosed down the engine bay (avoiding the dist and intake) and hit it with Simple Green. Could water have gotten into a connector or something to cause this?
Old Nov 26, 2008 | 04:35 AM
NGUSPEED's Avatar
Same issue friend.
Here is what Ive done ...
- Spark Plugs
- Spark Plug Wires
- Cap & Rotor
- PCV Valve & Grommet
- EGR Valve, Port, & Pathway Cleaning (2x)
- Tranmission Drain & Fill (with Honda MTF)
- Distributer 'O' Ring (I dont think this has anything to do with it)
- Multiple Bottles of Fuel Injector Cleaner
- Seafoam in the Gas Tank
Nothing works!
Old Nov 26, 2008 | 12:36 PM
213374U's Avatar
0x5359-0055
Community Builder
Not very encouraging
Old Nov 27, 2008 | 02:50 PM
Duane_in_Japan's Avatar
See if you have water in the spark plug holes???
Old Nov 28, 2008 | 08:13 PM
youdontneed2cams's Avatar
Try checking all your plug wires to make sure they are pushed in all the way, i had this same problem last week after detailing the engine bay.
Old Nov 28, 2008 | 08:55 PM
civicdelsol33's Avatar
Mine did this for years. I can't figure it out, but it hasn't done it in a long time. Alot of oil change after running gunk remover and using additives in my gas and it stopped?
Old Nov 28, 2008 | 10:40 PM
213374U's Avatar
0x5359-0055
Community Builder
Okay, got to thinking. Vtec engages at 2500 rpm, where the sputtering stops. The connection on between the harness and solenoid is jacked.... only a pin left on the solenoid side. I hit it with some WD-40 and played with it a bit. It still sputters but not like it was. Will only putt once (or not at all) and accelerate fine.
Going to replace the solenoid and connection and see what happens.
Old Nov 29, 2008 | 01:23 PM
dgkrzy's Avatar
Keep us posted - Many of us have a similar problem & are trying any and all suggested fixes
Old Jan 28, 2009 | 05:34 PM
Wdbjr12345's Avatar
Default Re: Bogging/Sputtering
thers water in your distributor just take the cap off and dry it out with a rag that will do the trick.
Thateguhate
May 19, 2011 08:04 AM
95BG33PGSR
Apr 6, 2010 04:07 PM
pchornung
Aug 10, 2007 08:52 AM
dynamitezz
Oct 28, 2006 08:07 PM
