ep3/s2k steering wheel fitment problem (pics)
steering wheel from a 2004 civic si hatch
going on 99 sh
I got the wheel to fit on there and bolt up wit no problem. I had to shave off one little plastic tab but other then that fits %100
Heres the problems i am having:
The airbag from the lude harness only has 2 wires, and the airbag now on the car has 4 wires, and the connector does not fit. What goes where?
Cruise control does not hook up, both have 3 wires but they are not color coded, what goes where?
Also cant figure out the horn ground
I loveeeeeee the wheel so far
This is the first of my red stitching theam i will have soon enough, about 2" smaller the the stock wheel
How easily does the s2k wheel bolt up? everything plug in? Has ANYONE done the ep3 wheel conversion? I choose this wheel because my brother has it on his ep3 and i love it, and it was only $200, much cheeper then a s2k which are around $350. ANY help would be great!
going on 99 sh
Is this steering wheel uses a two-stage airbag, it won't work. I've seen 5th gen's with the EP3 wheel. Here's the install for an S2k wheel, I'd assume it's the same for yours:
http://www.ntpog.org/mods/fifth-s2kwheel/index.shtml
LBCek9
Dec 22, 2005 08:40 PM
StreetRacinThug
15
Nov 27, 2005 06:23 PM
