how do you remove the rear mount on a d16a6
Old Nov 24, 2008 | 06:04 PM
acmoc's Avatar
Default how do you remove the rear mount on a d16a6
how do you remove the rear mount on a d16a6?
I can't find any way to do it, do you guys know any tricks tools I might need? I did all the others except for this one, it seems to crowded in their
Old Nov 24, 2008 | 11:36 PM
fireant's Avatar
I get to it from above, using a few different extensions and a universal joint from down between the IM and the master cylinder.
Old Nov 25, 2008 | 03:49 AM
silverkorn's Avatar
box wrench and a lot of patience.
Old Nov 25, 2008 | 05:09 AM
PISTONEMPIRE's Avatar
^^^Correct a lot of patience^^^
lol...that mount is a biatch!!!!!! I didn't want to deal with all that so I completely took off my intake manifold so I could get to it comfortably.
Old Nov 25, 2008 | 09:49 AM
1991civicsi's Avatar
I loosened up the front cross member, then I removed the two accessible bolts. Then, I tapped the mount with a hammer to turn it to expose the last bolt.
Old Nov 25, 2008 | 10:03 AM
4DRmafia's Avatar
removing that mount is nothing to me. I dont see what hard about it. There's 2 mounts back there, one on the tranny and the other on the crossmember.
chrisff521
May 19, 2010 06:06 AM
powerdbygarrett
Nov 4, 2009 10:34 AM
a1320addict
Mar 13, 2006 08:43 PM
CRseXy
Jan 20, 2005 12:06 AM
SurferX
Mar 3, 2003 02:16 PM
