98 accord vibration
Old Nov 24, 2008 | 04:51 PM
b1221's Avatar
Default 98 accord vibration
I have a 98 honda accord and it has started to vibrate a little in the steering column and can feel it a little in the floor on my feet. It gets louder the faster I go, but when I stick my head out of the car, I don't hear anything unusual. If I am turning left, the vibration goes away completely. I am taking it in to get looked at but wanted to get an idea of what might be the problem. Thanks in advance.
Old Nov 24, 2008 | 07:57 PM
cjo_28's Avatar
You hear the vibration? Generally you just feel vibrations. Does it vibrate worse under acceleration? Does it go away on deceleration?
If a vibration goes away when turning one direction or another, if it comes and goes with load (accel/decel), the first thing I check is the axles. If it is a bad axle, it's extremely difficult to isolate the axle that is causing the problem. It's usually better to just replace both axles.
Old Nov 24, 2008 | 11:00 PM
Duane_in_Japan's Avatar
Grab the axle just next to the inner CV Joint and shake it, by shaking both of them and if only one is bad, you should know which on is bad, hope its only one loose CV Joint. Change the whole axle though.
Old Nov 25, 2008 | 04:48 AM
P_Adams's Avatar
You may have a bad L/side hub bearing.
When you turn left, you unload the suspension (remove weight) and the vibration diminishes. If it gets more pronounced when you turn right, there's your confirmation cuz MORE weight is applied to the L/S Hub bearing.
You can sometimes find it by raising the front suspension and either grabbing the tire top / bottom and see if you can rock it in / out. You can also let the tire spin with the car idling in 1st (AGAIN RAISED :-) ). if you have a bearing issue, you'll be able to feel the vibration thru the lower control arm.
P
mikesp0008
Mar 20, 2018 05:28 PM
temp08
Sep 24, 2010 07:07 PM
tamadrummer1120
Oct 13, 2009 07:48 AM
MugenAccordSedan
May 8, 2004 06:45 PM
Fooman
Jun 3, 2002 09:14 PM
