clutch slipping
Old Nov 24, 2008 | 04:24 PM
makavelisolow's Avatar
Icon6 clutch slipping
i got a accord, with a h22 in it. car runs fine but the clutch is slipping. after i bleed it, it grabs and chirps second. we re-ran the line to the slave cylinder. it still slips and i need to bleed it everyday. i have thought about the Master cylinder, slave cylinder, the actual clutch pedal and the clutch kit itself. i have a stage 3 six puck with the pressure plate to put it if i need to put it in. any ideas at all?
Old Nov 24, 2008 | 04:35 PM
YeuEmMaiMai's Avatar
did u burn the clutch on the car? when you installed the clutch where you easy on it or did you start ragging on it right away?
Old Nov 24, 2008 | 04:37 PM
its a jdm h22a, those clutches are good out the factory, we took it to 7,500 every gear until 4th, to ensure gripping, and it gripped and spun tires.
Old Nov 24, 2008 | 04:41 PM
sorry its a motor swap, stock clutch, we did not change it or open the tranmission
DenisR
Feb 19, 2016 05:09 PM
blacklabel14
Feb 3, 2011 12:32 PM
vodkaTM
Dec 29, 2009 06:06 AM
Wazup
Aug 16, 2005 09:22 AM
94Vtecluder
Jan 31, 2005 03:56 PM
