engine running warm on a 90 accord ex
Old Aug 1, 2002 | 07:22 AM
mailforjon's Avatar
Default engine running warm on a 90 accord ex
neither of the cooling fans turn on unless the A/C is running. i hate A/C and i much prefer windows, but when the car is warm and i stop at a light, the cooling fans dont turn on as they normally would under such conditions and my temp gauge rises slighty (from 1/2 to closer to 3/4). however, when i turn on the A/C, the temp. drops immediately into normal range. any input/ideas/info/suggestions? thanks again. peace.
[Modified by mailforjon, 11:22 AM 8/1/2002]
Old Aug 1, 2002 | 07:27 AM
Brandon's Avatar
Life is Suffering
Default Re: engine running warm on a 90 accord ex (mailforjon)
Have you checked the coolant level? If the car does not have the proper level of coolant, the fan wont turn on.
Old Aug 1, 2002 | 07:33 AM
mailforjon's Avatar
Default Re: engine running warm on a 90 accord ex (accordvtec)
coolant level is fine. i just did a flush/fill recently. thanks though. someone mentioned something about a thermostat or the 2 ECT switches. one in the thermo housing, one in the water pump housing???
Old Aug 1, 2002 | 11:28 AM
smeister's Avatar
when was the last time you replaced your thermostat? i would start with that first. that usually is the problem. also, jack the car up and check underneath the car to see if you are leaking any coolant. the o=ring to the water pump on my car has started to leak, and im replacing that this weekend
Old Aug 1, 2002 | 11:30 AM
Brandon's Avatar
Life is Suffering
I forgot to say that you may have a bad radiatior cap. They are relativley inexpensive, and too easy to be looked over.
Old Aug 1, 2002 | 03:27 PM
CardDealer's Avatar
Banned
Modified by CardDealer at 4:25 PM 11/17/2006
Old Aug 1, 2002 | 09:02 PM
mailforjon's Avatar
Default Re: engine running warm on a 90 accord ex (schlit)
dont worry, i bought the helms the same weekend i bought the car. wouldnt buy another car without one. amazing stuff in there. i think ill replace both ECT switches (thermo housing and water pump housing) and see where that takes me. i actually ran into a Danco Transmission mechanic at work tonight who has a 92 ex and he said it might be those switches. i just did a flush and fill so id like to not have to drain everything again to replace the thermo. but i guess i gotta do what i gotta do. thanks for your help.
-jon-
azack_J
Nov 6, 2015 04:38 PM
mherrcat
Mar 20, 2011 03:04 PM
bow tie
Jun 25, 2008 02:38 PM
technine
22
May 9, 2005 12:47 PM
bigchokeslam
Jun 15, 2004 07:36 PM
