99-00 Civic Fog Light Install
ok guys i have a 99 civic ex coupe im trying to install some ebay fogs but i cant figure out which port on the fuse box to plug the output into any ideas?
Sorry for the bad camera picture
didn't the ebay instructions have a picture of which one to plug into? i can't remember, it's been over a year since i installed a set on a friend's car.
worst comes to worst, try it and see if you get power or not. if you don't, try another one.
yes everythings fin i have power from out the output of the relay but wen i touch the power to anyone one of thos ports i dunt get power at the fog light connector under the hood
Wait are you talking about the wire that has a female connector at the end that hooks up to the wire which I believe that both of them are red and it has a male connector, and the the brown plug goes on the 4th slot on the fuse box. Can you try and take a picture of the plug you are talking about???
ok on the fog light switch harness theres 4 wires a ground a + for the switch light a + for the fog lights and the brown female connector for the main feed to the fog lights its supposed to connect some were in the car that leads to the out side wiring
