Cylinder head threaded hole for valve cover bolt stripped, how can i fix it?
For the first time in 5 years, i did something terribly wrong (well something really stupid) on my car. I guess a mix of tiredness, cold temperature, and too much beer pushed didnt help me and i over tighten one valve cover bolt..Result; the threading inside the head is almost gone.
To make a quick example here is a schematic drawn by me, with the level talent of a 5yo.;
The valve cover bolt itself is in good shape. The main problem is that the fragile aluminium threading inside the head just tore off. It came out of it looking like a little spring while i tried putting back a bolt without the valve cover, to see whats wrong. So i am left with an almost empty hole (some thread left down there). I can "tighten" that bolt slightly, enough so i cant loosen it up by hand, but it's far away from the specified torque value.. BTW, it's the one on position 3 (or 2, depending on how you feel) in the tightening sequence of the valve cover.
The big problem is i take it off at least 2 times a year when i dont have any problem (maintenance, aka valve adjustment...belts verification, ...) So i am worried it will not hold for long.
What would be my options for repairing this mistake? I cant really use a bigger bolt since it will need to be much larger..? I tought about filling the hole using some (wich one!?!?) product that could become really hard and re-thread.. I feel really lost now.. Anyone has suggestions on how to save the day?!
BTW, replacing the head is out of the question
Ghost accord has the right idea. Helicoils or threadcerts are a viable repair for just such a failure; and they are used all the time.
Here's a video on YouTube that shows you how to do the repair:
http://www.youtube.com/watch?v=RFYa6sjhh_E
Helicoils are available online. As an example:
http://shopping.msn.com/specs/heli-c...1-5-metric-kit
and locally as well
P
and locally as well
P
gnarlycs
Jan 13, 2013 02:46 PM
hatchii
Nov 29, 2003 08:07 PM
