08 Si seats into EK
Anyone know what i need to do this? do they bolt in or do i have to swap rails or anything? do the EK rails fit on the 08 seats if i need to swap rails.
need some guidance!
need some guidance!
i think you need to use your civic rails...i seen a guy put the full 08 si interior in his em1. either you have to drill holes in the rails that come on the si seats or replace the rails...i think this is right. there should be a write up on how to do this.
blah im dead set on these specifici seats. so i guess im gonna buy them and then figure out how to put em in. since this is such a new topic to everyone, ill do a write up on it during my install....which will be available for the small price of $1.00 via paypal. anyone interested lemme know ;-) should be too hard with a cut off tool and a welder...hehe stay tuned for a write up!
ok so by the looks of what you did, looks like you need 2 cross bars going along the 08 seat rails. then you cut each bolt point and reweld it in a new further out location on your new cross bar?
do you have any clearance issues with the center console? how high do the seats sit?
doesnt look very hard to do. simple welding.
also do all the adjusters still work properly with your new fabbed rails?
and are all your bolt points cut from the 08 rail or did u need to cut some from your EM's rails?
everything fits and functions prefect. they sit the same height as the stock seats. I took the mounting tabs off my ek rails by drilling out the rivets then I test fit everything to make sure it looked good then welded the ek tabs to the crossbars i made up
Check out this thread, it has info.
https://honda-tech.com/forums/showth...=#post36452649
