ABS or No ABS
I have a 92 Civic Hatch CX...every thing stock..has the 1.5 non vtec...question...Im wanting to know if has ABS or not cause im getting new axles ..and i was told to check if it did but i dont know wat to look for under the hood...cuz my part supplier was talkin about a speed sensor ring on the axles or something
turn your ignition key in the on position... do you see an amber light that lights up ABS?? if not chances are you don't... you can also call your local dealer with your VIN # and they can tell you if its ABS equipped or not...
if you can snap a pic of your engine bay, i'll be able to tell you.. you are basically looking for the ABS pump which looks like a box with hard brake lines coming out of it.
and the only difference between an ABS axle and a non-abs axle is the gear tooths for the ABS. everything else is the same.
you all can correct me if i am wrong (which i probably am) but only the ex's and up came with ABS, right ?
Your car didn't have it as an option.
Models covered in this section with available ABS (they didn't all have it):
1994-1995 Civic EX ABS coupe
1994 Civic Si ABS hatch
1992-1995 Civic EX ABS sedan
1994-1995 Civic LX ABS sedan
1995-1997 del Sol VTEC ABS
1996 DX coupe (Eighth VIN digit: 5)
1996-2000 Civic EX ABS coupe (Eighth VIN digit: 5)
1998-2000 Civic GX ABS sedan
1996 Civic LX ABS sedan
I have seen alternators come in of unknown origin (but definitely not a match to the old car the new one is going into) to be traded for a core and there has never been a problem.
Most of the businesses seem to take it as a core is a core is a core.
The chance anyone would catch such a small difference is slim.
Rebuilt axles will usually have cores. New ones, of course, will not.
GI8U2racing
Aug 16, 2011 07:37 AM
jmurphy
15
Mar 29, 2011 04:25 AM
siblue_gzer
Aug 13, 2007 12:17 PM
