92 accord electrical problems
Old Nov 23, 2008 | 10:14 PM
dtenakoun's Avatar
Default 92 accord electrical problems
like the title says i have issues with my tail lights not working and my instrument cluster does not light up. everything else works great, and yes ive checked all the fuses all are good. thanks in advance
Old Nov 26, 2008 | 07:50 PM
P_Adams's Avatar
You've either missed the blown fuse or the multifunction switch on the steering colume went bad.
I'd recheck the fuses using either a 12v test light or a multimeter; I suspect you missed one.
P
Last edited by P_Adams; Nov 27, 2008 at 10:21 AM. Reason: Stupid sophmoric spelling error
Old Nov 27, 2008 | 06:06 AM
Pooby88's Avatar
Same thing happened on two of my Civics. If it isn't the fuse, it's likely the headlight switch. Try turning the switch slowly on and off. Wiggle it a little in the on position and see if your dash lights go on and off.
Old Nov 27, 2008 | 10:27 AM
dtenakoun's Avatar
Default accord
thanks guys ill look in to that
Old Nov 27, 2008 | 08:00 PM
bseriescrxsi's Avatar
install a radio lately?....if so you grounded out illum circuit....small light fuse under the hood
Old Nov 28, 2008 | 03:45 AM
doubleRdazz's Avatar
yea definitely recheck the fuses
im sure its happened to all of us
although one time my dash lights wouldnt come on because i had unplugged my dimmer switch
but that wouldnt explain the tail lights not working
Old Nov 28, 2008 | 01:27 PM
dtenakoun's Avatar
ok i did all that, checked all the fuses with a multimeter all good even installed a malfuction switch still nothing, and no i did not install a radio everything is stock, but what was you was saying about the illumination circuit fuse, is that located in the fuse box under the hood, because i checked all the fuses and they are good unless its located somewhere else under the hood, and thanks guys for all the help, keep it coming.
Old Nov 28, 2008 | 01:36 PM
dtenakoun's Avatar
also i have another problem my power steering doesnt work i change the pump but i still doesnt work
Old Nov 28, 2008 | 03:05 PM
P_Adams's Avatar
I'm sorry if I sound insensitive in asking the obvious question:
You are aware that there are two fuse boxes, yes?
Don't yell at me please, but it's happened twice since I joined the forum :-)
P
Old Nov 29, 2008 | 10:53 AM
dtenakoun's Avatar
yea iknow there is one under the hood and under the dash ive checked all with volt meter all is good changed th multifuntion switch, any other suggestions
Old Nov 29, 2008 | 01:31 PM
go back in the under hood fuse4 panel and pull the small lights fuse....check that one specifically
Old Nov 30, 2008 | 12:21 AM
dtenakoun's Avatar
okay thanks, ill check it for the millionth time, this time ill pull the fuse to see if its good, but like i already said, i checked all the fuses and the are good, also check to see if my brake lights work and they dont either, also i have a new problem, i cant get the car out of park unless i unlock the gear shift mechanism
Old Nov 30, 2008 | 05:35 AM
Duane_in_Japan's Avatar
Your brake lights and your gear shift lock are tied to the same problem, so now you have multiple problems. I was a little lazy and didnt read all the replies but dont just check for a bad fuse or two, check for powers around the system, maybe a loose connection at the fuse box???
Old Nov 30, 2008 | 09:49 AM
91EX4dr's Avatar
See if you are getting power to the brake switch. If not, or switch is bad, it will cause the shiftlock problem along with the no brake lights.
Old Nov 30, 2008 | 11:13 AM
dtenakoun's Avatar
yea i was just about to check that, thanks for the help
mike11
18
Jul 21, 2011 07:22 PM
mrmagic0097
12
Feb 18, 2009 01:46 PM
20_sec.hatch
Oct 22, 2007 03:31 PM
jdadams12
Nov 3, 2005 04:31 AM
henz
Jul 19, 2004 05:45 PM
